Welcome to Club SAITO !
Old 06-06-2020, 03:21 PM
  #46501
Glowgeek
Gadgets? Gadgets?! We need more stinking Gadgets!
Old 06-06-2020, 03:33 PM
  #46502
Hyjinx
Originally Posted by the Wasp
thank you for the good words! it just popped in my head and I went and made it.
a funny thing about, that Word Models P-40. people recommend only 5mm of Aileron throw. that's not much at all.
BTW, the plane has a 57" span and there are guys on Y.T. flying it with 91 Fs in it and one guy has a 26cc gasser in his.
Jim
Alas
Cant even speak that language.
My poor skills have limited me to trainer level bi planes😞
And my nerves are the better for it.
Sure love watching my brother in law "Chuck Yeager" fly his 1/4 scale single seat fighters.
It's awe inspiring for this poor old carpenter.
And enough for my nerves.
Old 06-07-2020, 06:23 AM
  #46503
b17freak
My Feedback: (32)
Default Keleo muffler
Any ideas on where I can get a keleo muffler for a FG-84R3 ???
[email protected]
thanks,
Bret
Old 06-07-2020, 11:35 AM
  #46504
Glowgeek
For all you YS haters out there you'll be happy to know the "low time" 91 AC/FZ I purchased doesn't run and needs about $80.00 in parts to revive it. Bearings, gasket set, oring kit, regulator kit and a thorough cleaning might git-r-done. Haven't even got it completely disassembled yet.
On a positive note, it is purdy.
Old 06-07-2020, 04:29 PM
  #46505
FlyerInOKC
FlyerInOKC's Avatar
That sucks!
Old 06-07-2020, 05:14 PM
  #46506
Glowgeek
Dang Mike, you need to work on being more candid.
Yep, not a good start. It'll be a beast when I'm done with it, albeit likely at a high price.
Old 06-07-2020, 05:49 PM
  #46507
FlyerInOKC
FlyerInOKC's Avatar
I'm sure it will scream when you are done!
Old 06-07-2020, 06:28 PM
  #46508
the Wasp
hey I don't hate YS 4st, I mean how can a guy hate a engine with a blower on it
Jim
Old 06-08-2020, 02:43 AM
  #46509
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
The trouble is, that $80.00 won't keep it running very long. You got off cheap, it's usually $100.00. The guys over in the YS Engine MFG Support Forum call it the HD treatment.
Old 06-08-2020, 12:13 PM
  #46510
GraniteGuru
Just bought an adapter for my FA120 Fatheads from Tru Turn and it calls for a 1/2" diameter hole in the prop. Just don't happen to have a 1/2" step reamer around.... Drill press I Suppose, but don't really trust it. I am using a 14-7 Graupner 3 blade prop so it is darned near impossible to hold it in place to do it on a drill press. Any ideas?
Old 06-08-2020, 12:20 PM
  #46511
Glowgeek
A 1/2" hole in a 14" prop?!
Old 06-08-2020, 12:33 PM
  #46512
acdii
Hmm, my MAS 14 x 7 3 blade has a 1 1/4" hub, so 1/2" is doable. Could always use a step bit once you have the blade centered. Step it until you reach the 1/2" diameter like a reamer does, then finish the hole with a 1/2" bit.
Old 06-08-2020, 01:06 PM
  #46513
GraniteGuru
There seems to be plenty of room. I went ahead and drilled it out by using a bit the size of the existing hole of the prop on the Drill press and centering the prop. I then braced it using 3- 1/2" square blocks clamped in place, removed the smaller bit and replaced it with a 1/2" bit and drilled it out. I am not totally confident that it is centered. I test ran the thing the other day and the engine "flew" itself off the test stand! I am not sure if it shook itself off or I didn't have it tight enough to the stand. Needless to say, I am a little skittish to try it again.....
Old 06-08-2020, 06:48 PM
  #46514
Glowgeek
The 180 is back together with new valve springs and bearings. Ran a 14 oz. tank through it set rich to blow out the castor assembly lube. Filled the tank again and almost got it tuned for tach readings when the sky opened up.
Safe to say, it's a beast!
Old 06-08-2020, 07:17 PM
  #46515
acdii
I'm considering maybe getting a 3D twist and run a 91 on it. Manual shows an 82. Would the 91 be too much or just right and what prop would I run? My Somethin Xtra is fun, but not capable of 3D without serious control surface work, as in making them all much larger. Besides I like it the way it is.
Old 06-09-2020, 03:37 AM
  #46516
Glowgeek
The 82 will fly it however a 91 or 100 and high torque servos will bring out its full capabilities. If it were mine I'd mount up a 91 with an apc 15x4W. Richened for flight it should turn right at 10k on the ground and in the air.
Old 06-09-2020, 05:12 AM
  #46517
acdii
15 4 sounds about right. I had to sit and think about the pitch and stuff and I finally got it. want to go fast on a horizontal, small diameter, high pitch, want to go vertical and don't care about speed large and low. So if I want to slow my Xtra down, then a 13 x 4 would work, but if I wanted it to go faster and be a real screamer, a 12 x 10. I think it has a 13 x 7 on it now. I really need to stock up on props, but when ever I go to a swap I find all these iddy biddy baby props no larger than 10". I don't have anything with a 10" prop, 11 is the smallest. Think I will get a pile of wood ones ordered after I do a list of sizes I use.
Old 06-09-2020, 06:01 AM
  #46518
Glowgeek
For wood props Xoar is a great choice. Not as effecient as an apc but excellent for thrust in the lower pitches and very popular amongst 3D pilots. Myself included!
Yes, for more thrust you need a larger diameter prop. That will force the use of a lower pitch prop to keep the engine rpms up in a usable range.
Yes, for more speed you need a higher pitch prop. That will force the use of a smaller diameter prop to keep the engine rpms up in a usable range.
Now here's the thing, when going for thrust (large dia, low pitch props) the engine will not unload much in the air vs. rpms on the ground. That means you can prop for a ground rpm close to what you want your engine to peak at in the air. When going for speed (small diameter, high pitch props) the engine can unload a lot in the air and over rev, especially with a slick airframe like a P51, so you must prop for lower rpms on the ground.
A good rule of thumb for prop loading is: Go up or down 2 pitch sizes for each 1" change in diameter. Example: 12x10, 13x8, 14x6 & 15x4 props would all provide similar loading to the engine and so peak rpms on the ground would be similar.
In the air it's a different story! That 15x4 may unload 200 rpm or so on a high drag 3D plane whereas the 12x10 may unload 1500 rpm on a low drag slick airframe!
All sounds simple huh? Well it is, for 3D and high wing planes (high drag) but not for speed planes. Predicting how much a prop will unload on a speed plane is an exercise in futility. You have to try a handful of props to see which one will produce top speed without over revving the engine. Cutting props down by 1/4" increments is commonplace with pylon pilots.
saito Saito SAITO!
Old 06-09-2020, 11:17 AM
  #46519
FlyerInOKC
FlyerInOKC's Avatar
This is one heart breaking post!
https://www.rcgroups.com/forums/show...-crashed-parts
Old 06-09-2020, 11:36 AM
  #46520
acdii
Wonder what a reasonable offer would be.
Old 06-09-2020, 11:42 AM
  #46521
FlyerInOKC
FlyerInOKC's Avatar
I suspect he won't get many so he may just accept the first offer.
Old 06-09-2020, 02:26 PM
  #46522
Glowgeek
Default FA-180 (The Beast)
Did the final tuning today.
FA-180
15% Nitro
Humid as all get out
APC 16x8 (sport)
Peak 9420
Idle 1650
HP: 3.156
Thrust: 16.52 lbs
For sale, a very low time engine with new bearings and valve springs. Immaculately clean inside and out. Piston ring still has factory grinding marks, not yet fully broke in imo. Runs great at all rpms. $200.00? PM if interested.
Lonnie
Old 06-10-2020, 02:35 AM
  #46523
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Wow, I just recently fixed up a 180 I got from Cap, it didn't need much.
Old 06-10-2020, 03:37 AM
  #46524
Glowgeek
Looks like a nice one Dave.
Just offering my 180 with the "Lonnie touch" here before posting on the classies. Someone will be mighty pleased.
Old 06-10-2020, 04:51 AM
  #46525
Danker16
I like the sound of that! The 100 flew it ok. I just noticed that the 100 and 125 have the same mounting pattern. Hmmmm, maybe I'll put the 125 in the TF P51 instead of the 115, that way I can put the 115 in my Strega 46-55 size bird as originally intended. Woohoo!
46 Size Strega + Saito 115 + APC 13x13.5N + left thumb sounds like a formula for fun to me
in regard to the top flite p 51 arf 64.5in would a saito 150 be too much for it? Im looking for a speedy p51. Or would the 71in p 51 hangar 9 be better suited?
