Introducing the TopRC Model Hawker Hunter - New Scale Jet
Hunter
12.7kg no way mine is defentyly heavyer.i mounted 2x4000 2s lipo 1x 3s Life 4200 and 1x 2s lipo 4000 for the Gear ans brakes. The cg is 24cm way back from the leding edge of the wing and i need extra leed in Front of the Gear.
For batteries I have 1 x 2s 1900mah life for turbine , 2 x 3s 2650mah for receivers , and 1 x 3s 1500mah for gear and breaks.
I'm looking at flying the test flight next weekend which would mean mine would be the first production model to fly that I know of.
Chris can you tell us what you did with securing the aluminium tubes inside the wings ?
Hunter
Ok my Hunter kit weight is the same as yours.i checken the weight complete with the Gear and your calculation is without.each Gear at the wing is 560g.the total weight of each wing is ca 2kg complete with linkage Gear servos and extra pylon Tanks.
For the Question i fixed it with a screw in the wing
#41
