Introducing the TopRC Model Hawker Hunter - New Scale Jet
#126
The legs/struts are the main issue on grass. They are made from really low quantity soft aluminium. They need the heavy grease removing and lighter grease adding to allow some compression.
Since the factory has the files for machining it would make sense they up their game…
Are you still flying your plane with the original gear?
Thank you very much for you feed back and help
#127
Mainly the rear. But the nose too failed (came apart at pivot) our grass is good and the Ripmax Hunters we fly from the same site have no issues.
The mechanics have been OK, it is the legs only that are super soft. The aeroplane is not mine, it belongs to a club friend. It’s still flying with modified legs, but still every flying session some maintenance is needed.
#128
I am currently building one of these jets. There have been several revisions of the U/C since this model came out a few years ago. mostly I think to the electronics (better controllers) and motor (square casing on latest versions). I dont know if the material quality of legs have been improved. Mine look fairly well made, as good as others I have seen from China and the motors work well (I m using an Electron controller on mine without issues) allthough not as nice as Electrons. Only thing which would not help on grass and poor landings is that the springs supplied in main oleos were rock hard and with no give and little damping. I ve replaced mine and added some damping oil from BVM so they should work better, Time will tell.
On a couple fo other aspects of this model, we know the fuel tank is well forward of the CG. These days, smaller engines do not need so much room and in mine I am using Xicoy X120, I did away with all the inlet ducting so the tank can go back several cms (still in front of the cg but nowhere near as bad). Still plenty of space for air flow and perhaps even some useful drag when flying! Also I felt the large tank would be sufficient for my flying needs so unless you want the second tank for smoke/10 minutes plus flying then leave it out and save weight. My model balances with 0 weight added up front (main batteries foward, bubble trap full, landing fuel in tank). Final weight TBA but since some people have flown this model with an 80N I should be OK! Overall very impressed with this jet, excellent build quality for price (all airex rear is very light, under £2k with retracts, tank, tube etc etc) and unlike some more expensive models I have bought, things like the UC doors are well made and actually fit with no mods! I am pleased that Dave reports that it flies well overall and look forward to flying mine later this year,
#129
We have never had an issue with the retract units (I don’t remember what shape the drive is.) The legs look very well made…but they are really soft. Particularly the lower leg which can bend turning too fast while taxiing.!
#130
Hi,
I have one that is flying with a 140 turbine, more than enough power. The plane flies great, no bad habits at all, very solid. The landing gear legas are indeed soft, anything harder than a greased landing will bend the lower main gear legs.I fly from paved runway, from grass I imagine you could have some problems if it is not smooth. In one of my landing I landed before the runway (flameout), and lower legs were bent beyond repair. Had to order replacement. Had to change the main gear springs to get some damping, from the factory there was nothing at all.
Over all I am happy with the plane, it flies great, it looks beautiful in the air and customer service is acceptable
Regards
Eduardo
Regards
Eduardo
#133
Dear All, my Hunter is mostly ready, I am wondering what are the travel for elev,ail and flap. Do you have a compensation on elev for the flaps? Do you use the airbrake? Thank you guys
#134
I used the settings in the manual as a starting point. Worked well for me. No elevator compensation needed when you deploy flaps with gear down and throttled back but some people may prefer a little down for the approach. Full flaps are effective at slowing model, so watch the power, You don't need the airbrake except for show . I do not reccomend landing with full airbrake if you want to avoid scraping your model. This is nice flying model. You will not be dissapointed Mine is very scale with a xicoy x120 but I ve not had a chance to fly with the wing tanks yet.
#135
#136
Hi
Factory settings are fine, maybe a little less aileron because full aileron rolls very fast. With low power and full flaps it drops fast so reduce power when you are certain you have made the runway.
Try to land it smooth, because if you land hard you will bend the LG struts.
Factory CG es very nose heavy. Use the CG mentioned in this thread. I started with 90 mm in front of main wheel axle, which is a good starting point
The plane is rock solid and flies very well and it is predictable. I love it, so much that I bought a bigger one (Feibao)
Regards
Eduardo
Regards
Eduardo
#137
I build the hunter with only one tank, the biggest, however I can not remember what is the capacity. I just mesure the small one at 1.5l. But I don't know what is for the other. Need that for my timer for my jetmunt 140xbl...
#138
#139
Can you show some photos of the Electron conversion? Any information about what size struts.wheels used etc would be useful. Thanks
Ed
#142
I ask a mechanic with lath to do the pin at 10 degrees (don't bend as you will have a poor cean angle). I cut the gear at 10 degrees too. For the front, I used the original but it is also crap, I will switch for electron or other good brands , should not be an issue for the front. Only point is how to attach the doors to the leg...but sure we will find a solution
#143
I think the Electrons will be worth the effort. I just want strong & reliable.
Cheers!
