Reload this Page >
Global Jet Club / Aerojet T-33 1/6 2M
Old 11-17-2020, 04:00 AM
  #51
chrisi f-18
Default T33
Hi Phil look at my pictures where I mounted my bvm Hopper tank. There is also a solution to make a support for the Intairco hooper tank. Greets chris
flep (11-17-2020)
Old 11-17-2020, 04:14 AM
  #52
chevronflyer
My Feedback: (9)
Originally Posted by flep
Hi Guys,
A Friend of mine and me just picked up our T33's and I have to say Quality is really good.
My Friend purchased an Intairco iTrap UAT for it and we dry fitted it on the Jet but noticed that with the cockpit we aren't able to put the canopy on as the cockpit does far down the to the fuselage.
We were both thinking how and where to install the UAT so that it works but didn't find any solutions now.
Does anyone use the iTrap and could tell me where you put it?
Regards,
Phil
did the next shipment just arrive? I am waiting on one myself? 🤞🏻
Old 11-17-2020, 05:51 AM
  #53
flep
Can't tell you because I got mine from Final Modellbau in Germany which still was in Stock.
Phil
Old 02-02-2021, 10:42 AM
  #54
chevronflyer
My Feedback: (9)
Are spare flex plates in stock for this jet or made to order overseas?
if like to get ahead of the curve on these, if I have a spare set then odds are I will never need them 😉
Old 03-11-2021, 11:09 PM
  #55
chevronflyer
My Feedback: (9)
Finically received mine.
what CG did those of you flying one like best?
Old 04-08-2021, 03:46 AM
  #56
mikes68charger
My Feedback: (34)
Anyone got flight reports on this? Dose it have the BVM snap?
Old 08-14-2021, 12:53 PM
  #57
F16Jeff
Default Getting close to maiden T33
Hi folks,
I have been informed the elevators were made too large for this scale. Suggestions to use less elevator and less flaps have been mentioned. Has anyone noticed issues with throws in manual for elevator and flaps?
Another thing, I have seen a couple CGs mentioned, one is 7 inches back from leading edge at wing root and manual shows 6.75 inches. Which is going to be good for maiden?
I am near ready to maiden my Ace Maker II. I have a kingtech 100G4 for power. Any tips before maiden would be appreciated.
Thank you,
Jeff
Aerojet T33 Ace Maker II
Old 08-14-2021, 01:04 PM
  #58
chrisi f-18
Default T33
https://www.aeroworldrc.info/t918944f9-T.html
Hi Jeff have a look at our global forum. I wrote my experience over the t33.
Greets chris
Old 08-14-2021, 01:35 PM
  #59
F16Jeff
Greets chris
Thank you Chris. I checked out the thread and gleaned the info I wanted. Also do you need to connect and disconnect your gear controller power supply? When I turn off the radio, my gear controller stays powered up. I have to disconnect the power supply to the gear controller to power down.
Thank you again,
Jeff
Old 08-14-2021, 02:04 PM
  #60
chrisi f-18
Default T33
Hi your welcome 😁👍
Yes of course disconnect the power supply of the gear after each flight and a note. Before you ready to start your engine!!! Let the landing gear in and out once so that your switch for the landing gear is in the correct position and to check that all landing gear is correctly retracted and extended again. I always do this before every flight and start the turbine
Old 08-14-2021, 04:26 PM
  #61
F16Jeff
Thank you again Chris. Appreciate the tips. I will report back once I maiden. Planned to do it tomorrow, but might wait until back from vacation in a couple weeks.
regards,
Jeff
Old 02-01-2022, 03:40 AM
  #62
airborn900
My Feedback: (25)
Is a k-100G2 a good motor for this Jet?
Old 02-01-2022, 04:44 AM
  #63
chrisi f-18
Default Turbine
Yes the best choice for this plane. Greets Chris
Old 02-01-2022, 04:14 PM
  #64
chevronflyer
My Feedback: (9)
I am at sea level and had a k120 g4 installed and it seemed very underpowered . The jet is really really heavy fpr
its size.
if I were you I’d sell it before the maiden goes wrong. This jet does not fly well in my opinion, many who own it would agree
Old 02-01-2022, 05:48 PM
  #65
emart
I have a SWIWIN 120 in mine . It flies great and tracks very well ,its just a handful to land ....if you land fast with little flap its not bad but if have to much flap like in video the elevator goes unresponsive then it kicks in and it balloons up . Talked to Mike at Global and he said they are working on new elevators for it . Hoping to get new ones for spring . Take offs and general flying it great ...Landings that's another story... I have about 10 flights on it and just land it on the fast side with minimal flap and some crow ,,,,only issue is we fly off grass so landing fast with non trailing link gear is very hard on the gear and airframe
Old 02-01-2022, 06:53 PM
  #66
F16Jeff
Mine has been ready for maiden since September. After seeing Mike's video of his having issues on landing, it spooked me. Also heard of the new elevators coming and hope this corrects the issue.
I did read not to use the recommended flap setting in the manual. Need to reduce it in order to not lose elevator authority.
In the meantime, I have other aircraft I am building and flying so my T-33 has been put on the side burner for now.
Old 02-09-2022, 09:06 AM
  #67
kevin
Any updates on this? Have new elevators been designed? Is everyone experiencing the same issue and does a more forward CG help at all?
"its just a handful to land ....if you land fast with little flap its not bad but if have to much flap like in video the elevator goes unresponsive then it kicks in and it balloons up . Talked to Mike at Global and he said they are working on new elevators for it ."
Old 06-12-2022, 04:18 PM
  #68
F16Jeff
New test elevators have been designed and the guys at Global Jet Club will be testing them soon. They received two sets to try out. I am looking forward to find out their results since mine is still hanging from the ceiling waiting to maiden.
Old 06-12-2022, 05:59 PM
  #69
Rod Hart
Same here except mine is in the basement. Beautiful Airplane
Old 06-12-2022, 06:21 PM
  #70
F16Jeff
Hanging from the ceiling or in the basement is not where they should be. These are beautiful aircraft and they should be at the field flying to show how nice they are. This way others would buy them as well.
Old 06-12-2022, 10:16 PM
  #71
chevronflyer
My Feedback: (9)
JP hobby has what looks to be a set of improved retracts and landing gear available for this jet .
Old 06-13-2022, 11:36 AM
  #72
Newton5019
Not waiting about for the factory, have a company in the U.K. modifying my current horizontal stabs to Scale elevators
fingers crossed
Viper1GJ (06-13-2022)
Old 06-13-2022, 02:51 PM
  #73
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
fingers crossed
Who is doing your mods? Any photos?
Old 06-14-2022, 03:39 AM
  #74
Newton5019
limited editions models in the UK
I have left it to him , so will post images and more details when completed
Viper1GJ (06-14-2022)
Old 12-21-2022, 04:54 AM
  #75
goshawk911
Default T33
Hi
I was having the same issue landing. I trimed the jet using flight modes with a slight nose up on full flap. This made all the differnce it will now land at walking pace with a little trottle on.
