Global Jet Club / Aerojet T-33 1/6 2M
#76
Hi
I was having the same issue landing. I trimed the jet using flight modes with a slight nose up on full flap. This made all the differnce it will now land at walking pace with a little trottle on.
https://www.youtube.com/watch?v=kTSR77zdmd0
Thank you,
Jeff
#77
using the old elevators and struggle to land it so with the C of G at 6.75” and trimmed for about 2 degrees of nose up with full flap. Using a little bit of power it now comes in nice with no pitching problems
good luck with yours 👍
#78
T-33 Assembly
Hi to all.
I received mine a little more than a month ago. Put an Acex 140 in it and due to that it is tail heavy. I put besides the 4 batteries a lot of lead below the battery tray so it can level. Had to fixed the rudder servo base, it was loose and also separate the fuel tank a little forward fron the original position. Yesterday, i was going for the maiden but Ali while checking it show me the flaps horns were a little bit loose so tonight i will clean everything and reglue it with hysol.
