Welcome to Club SAITO !
Old 10-19-2015, 04:53 PM
  #30226
the pope
Originally Posted by blw
I was talking about you bemoaning your nads shriveling up and falling off, or something like that.
Originally Posted by Old Fart
Barry over here they are called gonads while they are attached to the airframe but popey got rubberbanded yonks ago,he's still looking for his mountain oysters,dang things fall off and get lost.
Dave i used an apc 12x6 on my 62 it was the best flying prop i had for it,awesome inflight performance.
Well , Well , Well where are the mods when you need them ? The popes feeling a little unloved at the moment . Cheers
Old 10-19-2015, 06:36 PM
  #30227
acdii
Goatnads
SCHWING
This thread really went south, bunch of crotchety posters
Old 10-20-2015, 02:49 AM
  #30228
Rudolph Hart
Rudolph Hart's Avatar
Don't be stupid stupid
Old 10-20-2015, 06:11 AM
  #30229
Charley
acdii,
What's SSE stand for?
CR
Old 10-20-2015, 07:23 AM
  #30230
acdii
SIG Somethin Extra
Old 10-20-2015, 10:06 AM
  #30231
Sport_Pilot
Sport_Pilot's Avatar
Originally Posted by acdii
Goatnads
SCHWING
I think his name may be in reference to the freshness of his flatulence, not his age.
Old 10-20-2015, 12:15 PM
  #30232
Mein Duff
Mein Duff's Avatar
Hey guys... I just picked up a FA 82 about 10 yrs old / never been run...it has the hard plastic crankcase rear plate and carby support.
Is this something I should replace with an alu upgrade or is durable enough to stand the heat?
Thanks, Eric
Old 10-20-2015, 01:39 PM
  #30233
the pope
On the 82 the backplate is fine although I replaced mine with the alum. just because . If you do replace yours just remember you need metal thread screws to hold the carby on .The 72 is another matter with people having air leaking issues . This is what Ive read over the yrs and can be found with some searching if you wish . Cheers the pope
Old 10-21-2015, 04:40 AM
  #30234
Rudolph Hart
SIG Somethin Extra
I'm glad you said that,my guess was going to be south south easterlys or nor nor westerlies for the dyslexic.
Old 10-21-2015, 04:41 AM
  #30235
Rudolph Hart
Eric plastic backplates on the 82's are fine as popey said in a very civil manner,what's up?
Old 10-21-2015, 05:09 AM
  #30236
FlyerInOKC
FlyerInOKC's Avatar
Maybe he got into the single malt and it mellowed him out?
Old 10-21-2015, 03:31 PM
  #30237
the pope
You can tell I wasnt replying to you heh ! I just reread my post and it definitely needs some editing pope style but I'll just let this one slide ! Just a thought you may need a backplate gasket as well , I know the plastic one doesnt , been a while since I did mine so check out the parts list for the later one to make sure . Cheers
Old 10-21-2015, 03:34 PM
  #30238
the pope
Maybe one of old farts green cuban cigars ! Man had plenty of them in my day to kill a horse or at least send him into a coma or chew off one of his hind legs when he got the munchies . Cheers
Old 10-21-2015, 06:52 PM
  #30239
Mein Duff
Mein Duff's Avatar
Thanks for the reply Pope... I broke the engine in today and the back plate seems fine so far..I'll keep am eye on it for sure and replace with the alu replacement if needed.
Old 10-22-2015, 07:26 AM
  #30240
blw
blw's Avatar
OK Why would Anyone mess with the LSN on a brand new motor? I got my SSE with the newly acquired 72 on it out to the field, filled the tank halfway and started it up, it was so freaking rich that raw fuel was spitting out. I would up going nearly 3 full turns in on the LSN before it idled properly. I ran through that half tank in minutes just trying to get it to idle. I have it adjusted now on the fich side since it is a fairly new engine, I don't think it ran much, but I do know it was castor based just by the brown gunk on the muffler. The SSE flew pretty good considering its still sloppy rich on the HSN, lots of smoke and slime underneath from the crankcase breather. During tuning it backfired and blew the spinner off, so had to remove it and tighten the prop nuts, so I removed the crappy backplate too. Doing this lightened the nose by maybe a 1/4 ounce making the plane slightly tail heavy because I noticed as fuel burned off that it became pitchy and had reduced down elevator, so landed with a half tank left. Its on a new radio too so hoping all my issues with the engine quitting are over. The TC which is failsafe position will shut the motor off in a blink, so my guess is the Spectrum/JR RX was having issues causing it to failsafe briefly killing the engine. I think once this engine if broken in it will really pull this plane around nicely. I am running a 13x6 APC, but think I can go down to a 12x8 APC on it.
You are better off to put the engine on a test stand and break it in. Saitos are meant to be broken in sloppy rich for a while.
I felt the APC 13x6 was the best prop for my 72. How are you getting ground clearance?
Old 10-22-2015, 07:49 AM
  #30241
FlyerInOKC
FlyerInOKC's Avatar
I have always been a little anal about reading manual and any other documentation that comes with a new engine and following the break in procedures to the letter. That way if their is a problem I know who to blame.
Old 10-23-2015, 06:09 AM
  #30242
Rudolph Hart
I think barry was being really kind
Old 10-23-2015, 03:08 PM
  #30243
vertical grimmace
vertical grimmace's Avatar
I am looking at getting an FG 21 Gas engine. Does anyone have direct experience with them? What percentage of oil do you mix, and what have you found to be the prefered prop size? I will be using this for a large scale model. A Bates Moth minor. I am trying to decide whether I need to go up to the next size engine as well. It is recommended for a 120 4-stroke.
Old 10-24-2015, 03:43 AM
  #30244
Rudolph Hart
17x6.If they recommend a 120/125 glow fourstroke i'd go for an fg30.There's a vid on you tube of an fg21 being run up in a small waco.
ps some lowlife stole a new plant i put out the front yesterday.Next time i'll tie a short piece of string to the roots and put a grenade in first.
Old 10-24-2015, 01:43 PM
  #30245
FNQFLYER
Re the FG 21 use the factory data re oils and run in. Use the oil Saito actually supply, put an on off switch in the ignition circuit (apart from an opto or electronic off switch) and use it when the a/c is stationary and you should have no problems
Old 10-24-2015, 02:22 PM
  #30246
vertical grimmace
I am thinking the FG 30 might be better suited for my application. Although my plane will only be 14-15 lbs, it does have a 109" span. Similar to a PT 19, my aircraft is called a Moth minor in 1/4 scale.
So these Saito gassers like a 20-1 oil mix?
Old 10-24-2015, 02:25 PM
  #30247
SrTelemaster150
SrTelemaster150's Avatar
Figure at least a 20% increase in displacement to make up for the loss of power associated with gas. FG-30 would be a better choice.
Methanol has 27% more AVAILABLE BTUs than gas.
Old 10-24-2015, 02:28 PM
  #30248
SrTelemaster150
Most have gone to 15:1.
Old 10-25-2015, 01:22 AM
  #30249
Rudolph Hart
Right on the money sr although i don't get to fussed on oil brands,running klotz 200 in the fg57@20:1 because i already use that oil for my fa saitos.What are your thoughts on increasing the oil ratio to 15:1,a history if you like of what has happened re differing oil ratio use in saito gas fourstrokes.
Trev!! your alive!!
Vertical (or vert for short once we become mates) is that a jerry bates?(sp) kit? the moth minor is very pretty,understand why you want a fourstroke sound to finish the look and feel when you are flying it.As a bonus the fourstroke complements the look of a slow speed scale aircraft in flight because they give good acceleration from slow speeds with the right pitch prop as trev mentioned a few posts ago.The gas engines don't rev as hard as the glows so keep that in mind re the scale speed you want versus acceleration or easier landing when you throttle back on approach.If you've set the idle to suit the are easy to slow down and land in short places.
ps i run a wooden menz 23x10 on the fg57 which pulls around 5700 on the ground,factory benchmark prop(take a note here dave) is the apc 22x10@6500 which it did during run in.It's mounted in a blackhorse edge540v3 50cc two stroke arf.
pps for all the motorcycle fans whether you follow moto gp or not...you won't believe what rossi just did to marquez at the sepang moto gp round i just finished watching,i'm gobsmacked! and social media is in meltdown on the european side,i did'nt add any fuel to the fire
Old 10-25-2015, 06:34 AM
  #30250
acdii
Well the Saito runs GREAT! I have it set rich for now, but not so rich it wont idle with a full tank. I finally got a full flight in on the Extra, so must have been the RX causing the issues with the engine quitting. It has the plastic backplate, so now I know if I start having issues with ide to swap out that plate. I figured out why it wasn't running as smooth is it should, the intake valve was way out of adjustment. Once I got that in spec it now idles smoothly. When I was last out one of the guys had a profile with an 82 on it, running just as bad as mine did, so I got out my kit and adjusted his valves, and leaned the LSN a 1/16th, and it is running great now.
On the FG engines, I have been running 16:1 from the start and use Lucas oil. Been using that oil for a long time in my other 2 strokes and never had an issue. The only issues I have had is the damned Ethanol fuel eating the lines and seals in the carbs! Found I can get E Free Premium across the border so thats all I use now.
Can't wait to get the 72 fully broken in so I can get top RPM out of it and put the SSE to work! It is almost there, lots of vertical but not able to hover it just yet.
