Welcome to Club SAITO !
Old 09-05-2016, 06:11 PM
  #32001
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Actually the 1.25 has always had the new case, the 1.25a has a new cylinder with a wider included valve angle and larger valves plus larger cooling fins. Some say that was done to give the gas version an edge. I don't really know. I will make a velocity stack for it.
Old 09-06-2016, 02:32 AM
  #32002
Captcrunch44
That is interesting do all the new engines have the wider value angle and bigger valves. I have a saito 100 and 82 in the new case. It sounds like they will have more power for my astro hog
Old 09-06-2016, 03:12 AM
  #32003
SrTelemaster150
SrTelemaster150's Avatar
The new cylinders do not use "bigger valves" that I am aware of.
The revised castings are probably the result of the FG series of gas engines.
The FA-180B cylinder has much larger cooling fins & beefier material in the port areas to dissipate the additional heat from gasoline operation when employed on the FG-30. Saito just eliminated the old glow cylinders. It would't make economic sense to continue to make 2 different castings. The new cylinders will interchange with all of the previous series valve train parts & crankcases.
The valve angle does appear to be different. It will be interesting to see if it oimproves piston/valve clearance in engines that are modified for increased compression.
Old 09-06-2016, 03:37 AM
  #32004
Rudolph Hart
Rudolph Hart's Avatar
Originally Posted by Dave, FormerDairyFarmer
Here is the new 1.25a in a new kind of box, it seems superior to previous boxes, hopefully I can wring it out tomorrow. I've waited a long time to get this engine.
Jeez dave you know how to scare a fella,why did'nt you pm me before you opened the 125 box?
Hoping acdc will post a pic of the 125 and some tacho readings with one of the no go props on it.
ps everybody knows red handled scissors are bad luck pard
Old 09-06-2016, 03:41 AM
  #32005
Rudolph Hart
ps crunchy the old case and new case saito 82's perform the same as they should.
Old 09-06-2016, 05:17 AM
  #32006
acdii
no go prop? I dont use MA props!!! Only APC on my Saitos! I wanted to bench the Mustang yesterday, but it was too humid for my likings. When it gets humid, those damned squitos wont leave me alone, and for some reason, no matter WHERE I put my run up bench, they find me.
Old 09-06-2016, 05:55 AM
  #32007
Charley
Isn't the compression ratio higher for the glow versions? If so I wonder how Saito handles that.
CR
Old 09-06-2016, 06:31 AM
  #32008
SrTelemaster150
CR
Not in the case of the FG-30/FA-180.
They both employ the FA-180 piston. The cylinder has smaller FA-150 valves in the gas engine but I would bet that it is the same casting as the FA-180 so the combustion chamber volume should be similar.
There might be a slight increase in the combustion chamber volume due to the smaller valve heads in the gas engine, but not enough to make a significant difference.
Old 09-06-2016, 06:35 AM
  #32009
SrTelemaster150
Extreme humidity will reduce the RPM, especially if it is accompanied by hot ambient temperatures and/or low barometric pressure.
Old 09-06-2016, 06:51 AM
  #32010
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Re-assembling the 1.00, I used Dan's rubber band method to hold TDC, the pushrod tubes and seals are coming today by USPS in a couple of hours. New Boca Bearings and the new cam are in
ID:	2179842   Click image for larger version
Name:	Saito timing tool #2.JPG
Old 09-06-2016, 06:55 AM
  #32011
spaceworm
Use castor and stand behind in the prop blast. The squitos don't like either. Also, Listerene mouthwash sprayed around keeps them away. they don't like menthol or eucalyptus. Works for me. Good luck
Old 09-06-2016, 08:58 AM
  #32012
Charley
That's what insect repellent is for. I couldn't spend time out in my yard or on the deck without it. I also use an outdoor fogger now and then although I don't like the idea of killing beneficial insects too.
CR
Old 09-06-2016, 09:02 AM
  #32013
Charley
Listerene? No kidding? Have to try that; I keep the stuff in the bathrooms. Skeeters have been fierce since the drought was broken recently.
CR
Old 09-06-2016, 09:44 AM
  #32014
FlyerInOKC
FlyerInOKC's Avatar
I found a mosquito spray made from garlic oil you mix with water and a teaspoon of soap and spray on the trees, bushes, and yard works really good. You only smell it until it dries and it lasts until the next rain shower or 6 weeks. Works real good and it doesn't kill the good bugs.
Old 09-06-2016, 10:27 AM
  #32015
acdii
Thats why it wasn't to my liking. I don't fly when its that humid, so why tune to it.
Is this something you buy or make? Would give it a try too. I have 5 acres to worry about. My horses would appreciate ti too.
Old 09-06-2016, 11:10 AM
  #32016
FlyerInOKC
FlyerInOKC's Avatar
You buy it here is a link: http://www.mosquitobarrier.com/?gcli...FQkEaQodGywHRA
Old 09-06-2016, 12:54 PM
  #32017
Charley
Great! Give us the formula.
CR
Old 09-06-2016, 01:06 PM
  #32018
acdii
Well, 4 gallons would cover me for a year then. I have a sprayer that would do it too. My horses would love it since they will have garlic breath from the grass.
Old 09-06-2016, 01:27 PM
  #32019
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
The 1.00 is finished, it looks almost new, while comparing it to the new 1.25 I discovered the 1.00 had a crankcase vent with a much larger hole than the 1.25. Looking at other Saitos I found that the 1.00 vent had been drilled out or switched. It now has the correct vent. The muffler I put on it is larger than the rest of the 12mm mufflers I have so I hope it's the correct one. We have a huge Smoke Tree in front of our front door, skeeters come out of there in a cloud. anti skeeter stuff is a must.
I'll test the 1.00 with a Xoar 14x7 and 15x6.
ID:	2179919   Click image for larger version
Old 09-06-2016, 03:16 PM
  #32020
acdii
I found the 100 works really good with an Evolution 15x6 on the Cub. Not too fast at half throttle, just the right sound and scale like speeds, but open up to WOT and it tears a hole in the sky. A 14x6 APC gets the Cub off the ground into a pure vertical like an F-15 in 10 feet. I really like my 100, have to replace the bearings in the other one, have Boca sitting on the bench ready to be installed.
Old 09-06-2016, 06:19 PM
  #32021
Captcrunch44
Thanks for all that information guys. By the way mosquitoes don't like cold weather so I usually wait till it's below 60° before I do my real Flying and Then I don't have to waste money on all that Skeeter repellent.
Old 09-06-2016, 07:00 PM
  #32022
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I would worry if I put a 14x6 on the 1.00 just not enough prop to suit me, but that's me.
Old 09-07-2016, 04:35 AM
  #32023
Rudolph Hart
You beat me richard,that was the best joke i've seen here for weeks.
You guys crack me up and dave stop being so seriousof course a 14x6 is to small for a 1.00 my 82 will max a no go 14x6 prop out easy but hey...put that same prop on a 125 and watch it bog down
Old 09-07-2016, 05:43 AM
  #32024
acdii
So...10,500 is too fast for the 100?
Old 09-07-2016, 07:10 AM
  #32025
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
In my humble opinion, yes.
I just broke in the rebuilt 1.00, I did my usual:
10 minutes @ 4,000 rpm throttle about 1/4 open
10 minutes @ 5,000
10 Minutes @ 6,000
10 Minutes @ 7,000
10 Minutes @ 7,500 with short and then longer periods at full throttle.
Fuel Wildcat 10%/18% full synthetic
Plug===Fox Miracle and old well used one
Prop===Xoar 15x6 for all the above
Max rpm-8,900 rpm
Idle==1,835
Switched to Xoar 14x7, maybe some of you can explain this
Max rpm==9,790
Idle RPM=1,885
Exhaust==stock Saito cast muffler
I did not expect the 14x7 to turn faster than the 15x6, acceleration was wicked quick with the 14x7. I'm happy even though I spent about 65% of the cost of a new 1.00. The engine is still spotlessly clean after the approximately one hour and 15 minute run.
Pete, I may get to the 1.25a tomorrow.
