Welcome to Club SAITO !
Old 08-04-2017, 05:36 PM
  #34326
TJLeGault
If there is sealing compound there, Horizon put it there. I had the brass plate off at the field when I had it on the test bench because the spray bar had come loose I pulled the plate off so I could tighten the nut on the spray bar. I tightened the little nut on the bar and re-positioned the fuel intake to point back towards the tank instead of forward toward the prop. I am thinking that the position of the brass plate is important and I may have it installed incorrectly.
I told Horizon all this and to check the way it (the plate) was oriented, which I assumed they did. But maybe they didn't .
The fact is there is no visible physical damage to the carb, so I cant imagine why they couldn't get it to run. I will be disassembling the carb and looking it over. I think if assembled and adjusted correctly (bleed screw etc) it will run. I wish I had a parts breakdown of the carb so I could see how it is supposed to go together,
Before I noticed the spray bar was loose it started up and I just couldn't keep it going because I didn't have a good hold of the push rod on the throttle so it tended to fully close at idle which of course killed the engine. After pulling the brass plate off so I could tighten the spray bar down and reinstalling the brass plate, that's when it wouldn't start at all. So I think something is either not assembled correctly and\ or the bleed screw etc are not adjusted properly.
I used to overhaul aircraft engines and was a jet engine mechanic in the Navy so I got to think I can, with a little technical help, get this thing running.
I know it's an old engine but I built a TopFlite Gold edition P-47 with it installed and don't really want to go through the hassle of mounting a new engine that may require a different mount etc.
Thanks to all for the replies
Old 08-04-2017, 05:46 PM
  #34327
Captcrunch44
I have one new in the box with all the papers when i get home Sunday i will see if there is a parts break down on the carb.
Old 08-04-2017, 07:03 PM
  #34328
the pope
Originally Posted by acdii
aww the hot chevy babes are gone.
You my fiendish friend started this whole mess along with a few minor bit players . I apoligise for the very minor part I may have or may not have played in this whole ***** show . Now lets do get back to what were all here for , those fat chicks , I mean engines !
Old 08-05-2017, 02:49 AM
  #34329
Rudolph Hart
Rudolph Hart's Avatar
TJ i wish you good luck with the carby like others have said they are pretty simple but i don't understand them fully either.As an aside i have three 82's i've run over the years but only one carby out of three that gives me two to three hundred more rpm on all three engines,the other two carbys stay in a box.Somebody here will know the answer maybe.
ps richard spaceworm jnr..thankyou?? if i remember right you had a post deleted a couple of years ago for a very descriptive picture of a tall leggy blonde bird strutting around in black lace underwear,so what are you doing now?..sitting out on the front porch in a rocking chair whittlin or what??
Old 08-05-2017, 03:19 AM
  #34330
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
It could be a shadow I'm seeing, does the spray bar have a cats eye fuel inlet, or is it a t simple tube that just ends? If a cats eye it should pointing up towards the engine as in this 2.20 carb. I don't want to come across as condescending asking things you may have known for a long time. I've had a different Saito carb or two but never one like that.
Name:	Saito 2.20 carb 006 (Small).jpg
Old 08-05-2017, 04:27 AM
  #34331
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I think we need to consider that most likely there are no longer any, "Old Hands" at Horizon, they seem to have gone from some knowledgeable guys to guys who knew enough to be dangerous, as the old saying goes, and fed people BS and now guys who pretty much know all the buzz words for electric flight and little else. That's the Hobbsy take on that and it's free.
Old 08-05-2017, 10:24 AM
  #34332
acdii
It's free and I agree.
Oh damn, I rhymed
Hey pope, just think had I posted the Ford chicks! I might not be able to post again! Of course if I posted the real chevy owners vs ford owners one, they may take my internets away.
It's like Saito owners vs OS owners. Hot chicks, or fat chicks, your choice.
Old 08-05-2017, 01:08 PM
  #34333
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
There have been people who said that Saito come from the factory with some kind grease on the moving parts. I got a new OS .62v a couple of days ago and it's greased In the important places. It made black streaks coming out of the Saito 1.15.
Old 08-05-2017, 01:45 PM
  #34334
spaceworm
Default FA -120 abc Big Jug
Originally Posted by TJLeGault
Thanks for the replies, and I need all the help I can get.
Hobbsy
Can you tell me how to fix it?
spaceworm,
I sure could use tuning instructions and any other advice you could give me. I hate giving up on anything.
Sorry for the delay in getting back to you, just back from vac. in Maine.
Here is all I have on this engine, not much out there: A few pics, some words from Robison on tuning, discussion on ABC vs AAC, and a discussion on using 120 AAC cams on the ABC Big Jug version. Good luck. If you find out much more, let us know. I also have Clarence Lee's review of the early Saito 120. and a 120s manual. Let me know if you want those also.
Name:	120s (aac) cam in 120big jug abc.png
ID:	2226995   Click image for larger version
Name:	Air bleed carb as used on FA 120 abc .png
ID:	2226996   Click image for larger version
Name:	Bill Robison notes on abc vs aac.png
ID:	2226997   Click image for larger version
Name:	FA 120 abc Big Jug carb adjust by Bill Robison.png
ID:	2226998   Click image for larger version
ID:	2226999   Click image for larger version
ID:	2227000   Click image for larger version
ID:	2227001   Click image for larger version
Name:	lg-81293.jpg KMOTCUSTOM FA120.jpg
Name:	Saito 120abc.jpg
Old 08-05-2017, 01:54 PM
  #34335
spaceworm
Default Deleted post a few years ago?
Well OF, if I did, please send me a copy of it, because I don't remember it. bad case of CRS. No whittling, except on some builds I am working on. I had some health issues, some surgeries, some bad results. But, on the mend now and hope to maiden a few soon. I will continue to keep an eye on all of you and post if I can help. Very best regards to you and yours.
QUOTE=Old Fart;12357643]...
ps richard spaceworm jnr..thankyou?? if i remember right you had a post deleted a couple of years ago for a very descriptive picture of a tall leggy blonde bird strutting around in black lace underwear,so what are you doing now?..sitting out on the front porch in a rocking chair whittlin or what??[/QUOTE]
Old 08-05-2017, 05:25 PM
  #34336
TJLeGault
Hobbsy
Here is a picture of it. The slot points to the engine.
Old 08-05-2017, 05:34 PM
  #34337
TJLeGault
Here is the right picture (first one was from the other side)
The split is pointing toward the engine
Old 08-05-2017, 05:37 PM
  #34338
TJLeGault
Spaceworm,
Thanks for the info, and yes the reviews and manual would be great!
Old 08-05-2017, 07:33 PM
  #34339
the Wasp
edited 3 times LOL
wow wee, talking about back on topic
hey guys, compare the Saito 70 numbers in my link to> "10,400" with my OS 61FX w/Pitts Muffler on 20% with an APC 12X6
I'm impressed !!
http://www.rcuniverse.com/forum/tach...aito-72-a.html
see this one too,
http://www.rcuniverse.com/forum/tach...rformance.html
look at these 91 readings, I sure don't need a 100 in my ShoeString .60,,
http://www.rcuniverse.com/forum/tach...-readings.html
Jim
Last edited by the Wasp; 08-05-2017 at 07:52 PM. Reason: sorry for the edit, I'm getting old
Old 08-05-2017, 11:29 PM
  #34340
Rudolph Hart
[/QUOTE]
Yup! my bad.I wish you the best recovery,a good scatch build or even a cut out kit worked wonders for me when that happened.That was interesting reading on that old 120 carb,i'd be looking for an easier option? and nice pic of one of tom's saito's.
Old 08-06-2017, 02:29 AM
  #34341
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Yes sir, it's correct, I haven't seen any flaws in it yet.
Old 08-06-2017, 08:37 AM
  #34342
BarracudaHockey
BarracudaHockey's Avatar
I asked nicely, this is what we call your final warning. Next one will be in Moderated Status. Not really a step I want to take but lets just drop the off (WAY OFF) topic stuff please.
Old 08-07-2017, 03:31 AM
  #34343
BJ64
BJ64's Avatar
Anyone in particular that the above post is aimed at?
Not sure I quite follow...
BJ
Old 08-07-2017, 04:12 AM
  #34344
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Yup! my bad.I wish you the best recovery,a good scatch build or even a cut out kit worked wonders for me when that happened.That was interesting reading on that old 120 carb,i'd be looking for an easier option? and nice pic of one of tom's Saito's.[/QUOTE]
Well Pete, I was taking your advice yesterday and used an APC 13x6. to break in a new OS .62v. I've been playing with glow engines since 1956 when I was 14 years old I waited until yesterday to stick my hand in a prop. Seven hours in the emergency room, 27 stitches and much O Negative blood lost, hard lesson learned. One third of my middle finger tip is gone. Either don't use APC's or don't mention OS engines in the Saito thread. I am operating the mouse two handed. If I had been using a Xoar it would have broken and I wouldn't need any stitches. The .62 was turning 6,000 rpm at the time of the major blunder. So far I've been sentenced to three weeks of not,using the right hand.
ID:	2227178   Click image for larger version
  #34345
BarracudaHockey
Yes, the folks who's posts were yet again deleted.
Old 08-07-2017, 07:39 AM
  #34346
Captcrunch44
Ohooch
i got 15 stitches and lost a 1/4" of skin on my arm from a 18X10 APC. I don't know what was worse, the cut or the clean up of the plane and radio. That was a few years back when my planes started to get to big to hang on to. Now its tie down all planes. Hope you recover quickly. And do what the doctor says. Ha ha.
Old 08-07-2017, 08:22 AM
  #34347
FlyerInOKC
FlyerInOKC's Avatar
I think I'll stick to wood propellers!
Old 08-07-2017, 08:42 AM
  #34348
Cougar429
Cougar429's Avatar
Ouch! I use wood props for scale and early aircraft flights just in case. Had a Graupner on a pusher last summer that ate the middle fingers of my left hand. Ugly, but fortunately came out O/K.
Think that was the only bite since my first 40, (with an unsanded M/A prop) over 30 years ago.
Have been acquiring more Saitos over the last year. A 56, 65, pair of 82's, same with 100's and another 125 a few weeks ago intended for a Gee Bee Z.
Old 08-07-2017, 08:51 AM
  #34349
FlyerInOKC
FlyerInOKC's Avatar
When my teenage son first started flying with me I let a piece of paper go to fly into the propeller passing thru in the blink of an eye. He got a lasting impression from the cuts every 1/4" in the paper and the split second it took to happen. He has a healthy respect for the fan on the front! I still remember the pain from bites I got from just starting a Cox .049 back when I was a kid, I'm still wary how close I get my digits to a spinning prop.
Old 08-07-2017, 08:52 AM
  #34350
acdii
OUCH, though not near as bad as a fellow club mate. He had his plane on the run up stand, but being a high wing the leading edge on the left wing jumped the hold back when he throttled up and the plane spun around and clawed through his right arm. It was a wooden prop, but was a 22" one. He was taken away in a Flight for Life chopper. His first ride in a chopper and he doesn't remember it. He now has ridges through his arm where the prop chewed through the muscles, but they did a good job putting his arm back together, has almost full use of his hand.
