Welcome to Club SAITO !
Old 08-11-2017, 07:04 AM
  #34376
FlyerInOKC
FlyerInOKC's Avatar
Nice tank Pete, well done!
Mike
Old 08-11-2017, 06:35 PM
  #34377
the pope
Nice job there O.F. AGAIN ! I would love to see u paint a plane . Ever done one ? Cheers
Old 08-11-2017, 06:38 PM
  #34378
the Wasp
OF, your holding out on us, show us photos of them there planes
your buddy
Jim
Old 08-11-2017, 10:59 PM
  #34379
Rudolph Hart
Rudolph Hart's Avatar
Many thanks guys,glad you liked looking at them.As far as painting my own planes well i hav'nt done that since i was ten years old and my dads soon to be not best friend loaned me his beautiful p40 to put on a big shelf in my bedroom.Spent hours looking up at that aeroplane on the shelf before i just had to take it out into dads shed when everybody else was out.Luckily dad had the right shades of housepaint to mix up some nice camo colours and a three inch stiff bristled paint brush,couple of hours later i stood back proudly watching it dry and thinking maybe i should'nt have painted the canopy.I could tell people were shocked when they saw it.So,i never painted a model aircraft again tho i've painted lots of full size one's from heli's to jets.I've got an old 2000 model v6 toyota camry wagon i put my planes in when i go flying and it's got primer patches on it,so people say 'when are you going to paint it' and i said to the mechanic who asked me...when are you going to do the valve guides in your smokey old heap,he just laughed.
Dave if you know someone who owns a rocket three go for a ride,absolute stump puller.I would'nt like to be buying rear tyres for it tho they don't last long.
Old 08-12-2017, 03:21 AM
  #34380
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
SAITO FA-40a
This is an engine test by Bill Jensen that I had not read before , I have two of these, one has not seen fuel,yet. I have two Xoar 11x6's coming so I can play when my fingers are well again. A Saito FA .40a and an earlier FA .40 side by side.
I'm just beatin in time while my fingers heal.
Name:	Saito .40s 002 (Small).jpg
ID:	2227701   Click image for larger version
Name:	Saito .40a and .40 007.jpg
Old 08-12-2017, 07:36 AM
  #34381
Bipelover49
Default Tuning issues FA450r3
Hi all, new to this thread. Looking for help from a saito tuning expert. Figured this should be the place. I recently purchased a NIB old stock FA450r3. I have three other saitos, 125, 182t, fa300t. Have had good luck with all so far but am a little concerned about the tuning results so far with the radial. Broke it in as instructed, I use 20/20 Power master fuel, 22/10 Falcon wood prop, on board glow for start and idle. I started at 5turns out on the HS needle and the engine started fine, idled fine and ran at moderate varying speeds for three 32oz tanks with no problems. On the fourth tank I attempted to start leaning the HS needle. When I first went to WOT she tached at 6800 but after 15 to 20 seconds she died as if starving for fuel. On the next start I began turning in the needle but that caused the WOT run to end even sooner. Even though I was at 5 turns out on the third run I began opening the needle gaining run time and eventually ended up at 6 turns out. The engine idles great, transitions great runs 6850 at WOT, flys the plane great but seems to run very rich. I would think this engine should end up around 3 1/2 turns out. Have I missed something or is the radial a different animal? Any advice or help would be greatly appreciated. Thx BTW I have about 15 flights on this models with no issues with the engine except for what I think is way to rich running.
Old 08-12-2017, 08:57 AM
  #34382
c550
My Feedback: (16)
I srtuggled with my 450r3 for a while trying to balance the cylinders. You might have the one on the lower left not running well(too rich). I solved it by converting it to glow ignition from C H ignitions. But I never got closer to 5 or 6 turns out when tuning, before or after the conversion.
Old 08-12-2017, 08:12 PM
  #34383
the Wasp
I have two of these
Hobbsy ??, your 40s photos ?? is that what they call "Love Birds" ?? it looks like the one on the right is trying his stuff with the one on the left oopss
LOL
Jim
Old 08-13-2017, 01:42 AM
  #34384
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Well now, I just don't know, I cured that by selling the FA .40.
Old 08-14-2017, 01:52 AM
  #34385
Rudolph Hart
LOL
Jim
Jim put your glasses on when you look at two supposedly same size engines side by side buddy
Bipelover i read your post with interest because i like the 450 triple and have seen one flown at the club.I have a 200r3 and it does the same thing ie running rich on one bottom cylinder so i used to leave a glow stick on that pot when i was setting the idle and transition speeds.I believe there was a previous discussion here between dave and his friend dan about a modification to the 450 that evened out the fuel distribution,i think that was combined with a ch ignition but still running methanol.The modified 450 was flown in a big corsair and was on you tube,hope this helps keep us updated please.
ps boy did it sound good and plenty of grunt.
Old 08-14-2017, 07:50 AM
  #34386
Bipelover49
Hi thx for the info. I did have a problem with one cylinder dropping out with extended idle, but after installing the onboard glow set for idle that issue was cured. I saw a you tube video by CH Ign that shows the conversion to Ignition that still uses glow fuel. He explains that with that conversion he now has the HSN set at 2 1/2 turns out. Which leads me to believe that normally it would be around 3 1/2 turns out. Would you agree?
Old 08-14-2017, 08:39 AM
  #34387
c550
My Feedback: (16)
No, I think there are a lot of factors other than just the engine that will affect the final position of the needle. i.e. tank position length of fuel line run and fuel line size. Mine never came close to being tuned in with the needle less than 4 or 5 turns out. With the ignition it runs with much less fuel. I will check it and re tune for the fall flying season, but not till we have a heat index much lower than the 105 we will have for August here in Texas. I wouldn't worry about how many turns on the needle if you can tune for a good idle and transition, and can get a top end just rich of top rpm you are doing good. If you cant get it to do that try the C H mod and that should solve your problems.
Old 08-15-2017, 03:38 AM
  #34388
Bipelover49
Thx again for your help. The engine runs really well as tuned and fuel consumption seems close to what saito expects, so I'm going to relax and just fly it. Just was a little concerned and didn't want to harm the engine. Regards BTW, I use a 2s lipo 20c 4000ma batt for my on board glow. After five 10min flights the batt still has 80% capacity left. How does that compare with the CH conversion setup you are using?
Old 08-15-2017, 03:58 AM
  #34389
Bipelover49
Hi, your right about the sound and grunt, when I fire that up everyone else at the field stops to watch the show. LOL
Old 08-15-2017, 04:06 AM
  #34390
Bipelover49
One other thing I did was to setup my onboard glow to a separate channel on a toggle. So instead of a throttle set point I can switch it on and off as needed. I've been leaving it on from taxi right thru liftoff then switch it off. Then back on for the landing approach and taxi back. Been very reliable and relieves the anxiety, if you know what I mean. LOL
Old 08-15-2017, 04:18 AM
  #34391
Rudolph Hart
Hey now that's a good idea if you are not confident about all cylinders staying alight on taxi out and power up or approach,i've never tried that.You are right the 450 triple sounds awesome,i'd like saito to make us a 440 kinda inline twin so i could run short shotgun style pipes out the side of the cowl on a bigger mustang or similar...yeah i think i'm dreaming.
Old 08-15-2017, 10:06 AM
  #34392
c550
My Feedback: (16)
I have a 2000 mah Life battery, It can do about three flights before I recharge it.
Old 08-15-2017, 11:09 AM
  #34393
Captcrunch44
Putting a 125 in my hog bipe what the bench mark prop for the 125.
Old 08-15-2017, 01:10 PM
  #34394
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
16x6 @ 9,000 rpm.
Old 08-15-2017, 01:58 PM
  #34395
Captcrunch44
Originally Posted by Hobbsy
16x6 @ 9,000 rpm.
that little engine will turn that at 9,000rpm. Cool vary cool. I should be able to get some vertical out of it.
Old 08-15-2017, 02:02 PM
  #34396
Captcrunch44
Hobbsy
hows the hand? Hope its healing well. Since you posted that I can't believe how many other prop strikes there's been in the last month. So you're not alone.
Old 08-15-2017, 04:46 PM
  #34397
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
It's doing well but too slowly to suit me, I see the hand guy again Thursday and I should be done with him. I took the last antibiotic and 6 pm, been off the pain pills since Wednesday. Progress is happening. Thanks, Dave
Old 08-15-2017, 09:22 PM
  #34398
the pope
Best to save the pain pills for when u dont need them . Like a party etc . Wash em down with some whisky !
Old 08-16-2017, 02:55 AM
  #34399
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I am not a weakling who does such things.
Old 08-16-2017, 03:07 AM
  #34400
Rudolph Hart
Well i am i think the pope has a point.Dave what do you think on the merits or otherwise of saito going a little bit down the kolm engines road and producing,in effect,a 7hp 440 or bigger TI twin using the existing 220 single,on glow fuel it would be a monster.Maybe menthanol and ignition or gas?
ps i like the fa220 in silver rather than the gk version because saito spent a lot of time polishing them.
pps capt44 re the 125 you can't polish a turd but you can wrap one in glitter..
