Welcome to Club SAITO !
Old 08-31-2017, 10:55 AM
  #34601
blw
blw's Avatar
Pete- you got me there. I get the fever a couple of times a year without any help of going into bike shops. I've already told the wife a bike is in her future and we have had a few semi-harsh words on that. She's already at her limits with the S 2000 and I need to tone down the driving habits some. Hey, the bike on the left is what I need. And, no saddlebags. There's few words for what I think of that junk. Bare bones motorcycle- the manly way to ride. That is a nice modern & retro look. I don't know. You have me looking at Ducatis now.
Wasp- that's probably a pencil drawing of the cowling. It could be an etching if someone wanted to go through the trouble. I took etching classes in college and maybe that is one.
Old 08-31-2017, 11:59 AM
  #34602
acdii
I would prefer a Trike, only because I don't like bikes.
Old 08-31-2017, 04:47 PM
  #34603
the Wasp
Hpbbsy,
Bill Robison was convinced that if you put a cold plug in the front of cylinders you could have a sort of ignition curve
the guy I got my 130 from had different plugs in it from front to back,, this must be what you mean by "ignition curve"
Jim
Old 09-02-2017, 03:26 PM
  #34604
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
AC, you were supposed to get your package today, any news, Thanks, Dave
Old 09-03-2017, 08:36 AM
  #34605
acdii
Out of town on a camping trip, will be home tomorrow afternoon.
Old 09-04-2017, 03:55 PM
  #34606
numbers
Default new FG-30b
Hello Saito friends,
Just got a new FG-30b running and flying at Indiana Warbird Campaign this weekend. Installed in a 92" Kangke Monocoupe, 17x8 Zoar prop, 91 octane gas, 20:1 redline oil mix. Engine fired up fine with electric starter, ran 10 minutes below 4000rpm on the ground, then flew it without issues the rest of the weekend. Factory needle settings are turning the 17x8 a little over 7000rpm.
Couple questions:
1) The engine sounds like it's hitting peak rpm before the throttle barrel is fully open. When opened further it sounds bogged down, although I didn't really notice a drop in speed or pulling power. Does this mean the high needle needs adjusted a bit?
2) And now for a "senior moment" question. I didn't really look at the high speed needle screw very well before I installed the engine, just noted the general location of it. Now it's cowled in, and I can't see it. Looked in vain on web for a good picture to no avail. With a small mirror, it looks like it's really inset into the carb body and has a tiny slotted screw. Is that right?
I've had .72 and .90 glow motors, best engines I ever had in 30 years of modeling. Can't say the same for the glow 170R3 though. I hope the gas FG-30b is a good one.
Old 09-04-2017, 06:57 PM
  #34607
Captcrunch44
Boy
i don't want to sound bad but. I flew the hog bipe with the 125 and a 16X8 and it seemed to be way over proped. I didn't get the kind of vertical that I thought I would with that engine. Has anyone run say a 15X8? How ever it did run good its a *****cat of an engine.
Old 09-05-2017, 02:48 AM
  #34608
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Numbers, the HS needle appears to be verticle under the carb, the LS needle is inside the carb barrel. In the Horizon manual a vague picture is on page 17.
Old 09-05-2017, 05:45 AM
  #34609
acdii
Couple questions:
Gas engines seem to reach max RPM well before the throttle is fully opened. That, and the fact the engine is no where near broken in, it has to run richer, which also affects top end a bit. I have an FG-11, same thing, reaches peak RPM well before WOT, and since I am still using break in fuel(after 2 years on the first gallon!), it has a heavier oil content too. Next gallon will be fresh fuel with the proper oil mix, I mixed the first gallon 16:1 since I wasn't seeing any oil residue in the crank case and was concerned, but not any more, getting plenty of lube. Great running engine too.
Old 09-06-2017, 03:39 PM
  #34610
blw
blw's Avatar
CaptCrunch, try an APC 15x6 and see how it performs. Maybe it will get better.
We're in Panama City Beach, Florida right now. Florida is going to get hammered hard by hurricane Irma. We drive home on Friday.
Old 09-06-2017, 03:50 PM
  #34611
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
A 15x6 would be too wimpy for the 1.25, a 15x6 is perfect for the 1.00.
Old 09-06-2017, 07:06 PM
  #34612
acdii
Looks like it will hit lower Florida as a Cat 4, but as of now it is the most powerful hurricane ever recorded, which means it will surpass Andrew in damage. The keys could get wiped out from the surge.
Old 09-06-2017, 10:29 PM
  #34613
Broken Wings
My Feedback: (20)
Broken Wings's Avatar
I had a first year 900 Super Sport, white wheels, white frame with that beautiful Tomato Red paint.....it was blast to ride but a torture rack for anything longer than an hour in the saddle. The sounds it made were music.....Loud Clutches save lives......
Old 09-07-2017, 02:48 AM
  #34614
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Barry and I good naturedly go round and round about the 15x6 vs 15x8 prop on the 1.25. my newer version turns a Xoar 16x6 at 9,000 +, that might be the way to go.
I had a 1962 Harley Pacer 175 cc two stroke and my friend had a 200 cc Ducati with the Desmo valve train that rattled louder than a Mack 711. Every once in a while we'd get into an impromptu drag race. The Duck was geared fairly tall and didn't launch very well, I would always jump him for about 50', but when he hit second gear he was gone. He left me in the dust at that point.
Old 09-07-2017, 05:02 AM
  #34615
acdii
When the 125 in the Mustang runs, it rips that Scimitar APC I have on it. Not sure what the size is, probably 15 x 8, but it's the first plane of mine to Doppler as it flew by. Loved the sound it made. Now I just need to get it running again, haven't tried since I cleaned it out.
Old 09-07-2017, 06:54 AM
  #34616
Captcrunch44
Well this weekend i will go out and test it all out. And let you know. I was in Texas and it was hot. So maybe up here in good old Iowa it will get better. Not Houston a place bay waco
Old 09-07-2017, 06:58 AM
  #34617
acdii
I think I have a future home for my Saito 91. Going to build a 4*60 with Retracts. Should make for an awesome flier. All I need now is the plane.
Old 09-07-2017, 07:26 AM
  #34618
Captcrunch44
Well don't buy one ow I might be able to help you out. Things slowing up i can get to the post office.
Old 09-07-2017, 07:54 AM
  #34619
acdii
Copy that. Going to be a while still before I start cutting, still have a few planes to work on, but would like it ready by next spring.
Old 09-07-2017, 10:25 AM
  #34620
Captcrunch44
Cool man
i would like to see that at SIG.
Old 09-07-2017, 11:56 AM
  #34621
blw
blw's Avatar
Dave, the water at Panama City Beach looks like I've never seen it. There are no waves. None. The water is flat and comes in at a snails pace. Eerie looking. Must be due to barometer. We are leaving for home tomorrow.
Dave, I thought that thing was over a 15x6 vs 16x7. It doesn't matter. There was a bit of talk about 125's shipping that were low revvers, like mine. W8YE thought people were being fooled due to the extra hard chrome used. He said some engines needed 3 gallons to break in. My 125 needed a lot to settle down. Maybe more than 2 gallons. For some reason, some 125's were slow revving. Ithink all this went away with the b model.
Old 09-08-2017, 02:58 AM
  #34622
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Sorry Barry, I won't bring that up again, in fact it was me who a few years ago said that the early 1.25 non A, was a 9,000 rpm engine. I have been trying to find the engine code for the early one to no avail. All that is out there now is the 1.25a info. I'll keep diggin. I am trying to determine if the valves are larger in the 1.25a. Jim thinks they might be. This picture is old news for most, early 1.25 cylinder on the left 1.25a on the right.
Name:	Saito 125 old and new.jpg
Old 09-10-2017, 05:30 PM
  #34623
blw
blw's Avatar
I was sort of the oddball with the low revving engine. Breaking in was difficult too.
Old 09-10-2017, 06:24 PM
  #34624
acdii
Flew my Saito FG-11 today, had a dead stick because I ran too lean. OOPS. Gave it an adjustment and flew again, and it ran great. I'm on my last tank of the first gallon, so a fresh E-Free Premium will help with leaning it a bit better for more power. The fuel I have is so old that the oil content is probably 10:1. I got a lot of oil on the side of the plane. Problem is that it is so efficient that a 10 ounce tank lasts forever.
I have a problem with the Optikill though, wont shut off no matter what.
Old 09-10-2017, 07:20 PM
  #34625
Captcrunch44
Well I didn't get to run my 125 today, i had to put in carpet and work on a real airplane (Air tractor)
