Welcome to Club SAITO !
Old 05-16-2021, 02:50 AM
  #50376
1200SportsterRider
1200SportsterRider's Avatar
Lose the castor, it is not needed, I haven't used castor in my fuel nearly 20 years.
Old 05-16-2021, 03:11 AM
  #50377
Glowgeek
Lean out the lsn and keep 2-3% castor. The lsn controls fueling from idle to upwards of 80% throttle. Some, but not all Saitos run very rich in the midrange when the lsn and hsn are set up to what we would call acceptable standards. That is, 250-300 rpm rich of peak and a sustainable idle with snappy transition. If you spend all of your time flying at 0-50% throttle adjust the lsn for cleaner running at those rpms. Once you get it running leaner on the bottom end you may find it wants to cough out and die when slamming the throttle open from idle. If so then slow your throttle servo speed a bit.
Old 05-16-2021, 05:15 AM
  #50378
Hyjinx
Originally Posted by 1200SportsterRider
Airplane ready and airplane hauler reader, the Leer 180 XL cap was installed yesterday, the K&N pipe, (by me) the day before. I'll most like fly the 62 with a Turbo Header. Jim, do you have any Turbo Headers? Thanks
Sig Four Star with Saito 62 and 12 x 6 three blade.
NIce cap. Now you can keep the daily flyers assembled in it for quick morning jaunts to the field😉
Looks great with the slash cut.
Old 05-16-2021, 05:56 AM
  #50379
Glowgeek
Looks great Dave. Now all you need is some custom 22" wheels with "rubber band" tires and then you'll fit right in.
Oh, a drop kit would be awesome too.
Old 05-16-2021, 09:06 AM
  #50380
modeltronics
My Feedback: (27)
Dave, I have a similar topper on my Chevy Colorado. About 3 or 4 times a year I have to slide the topper back about a foot to clean the back cab window and the topper window. If I don’t it gets to the point I can’t see out of the back. Part of the problem is that I live on a gravel road and the road dust gets in there.
Old 05-16-2021, 11:38 AM
  #50381
acdii
I ordered my topper to have a drop down front window, makes cleaning them so much easier. Since I had to buy new, might as well get that option. Finding a used for a 2016 was near impossible.
Old 05-16-2021, 03:44 PM
  #50382
1200SportsterRider
I too live on a dirt/gravel road, that dust on the pipe tip id from a single trip. Thanks all.
Old 05-17-2021, 03:15 AM
  #50383
1200SportsterRider
Actually I was considering raising the front 1.5" so it would sit level front to rear but since it has struts with huge A frames/arms at the bottom, raising it would change the angle of the A frames/arms The rack and pinion steering looks as if it would work on Peterbilt.
Are there any Saito you guys would like to see run with certain sized props? I need something to do besides mowing.
Saito 50
Old 05-17-2021, 03:35 AM
  #50384
Glowgeek
When I was a teen I remember my Dad's F150 having a Leer Bed Topper. IIRC there was an inflatable donut that went around the rear truck window between the cab and topper to keep dirt and grime off.
Old 05-21-2021, 03:36 AM
  #50385
1200SportsterRider
I keep coming back to installing this Saito 182 on the Rascal 110, I think it's doable, there won't be a lot of the cowl left, but.
Old 05-21-2021, 03:52 AM
  #50386
Glowgeek
How about a split cowl? It's not too hard to put in a couple of basswood beams for it and you have to cut away a lot less cowl, usually. Those intake tubes and needles make it a challenge either way.
Old 05-21-2021, 04:05 AM
  #50387
Hyjinx
Looks like a perfect fit. Even mo betta, the heads and valve covers will peek out the sides for awesome aesthetics and great cooling. I have mounted my 300 twin (lesser liked OS) on a third scale spacewalker and it is eye catching as it passes by. And idles all day long with no onboard glo thingies. I say go for it Hobbsy! And send video!!!
Looks like an offset to the left? never seen that before?
Unrelated but Saito. Like to learn the history of the R3 engines. This series with its multiple problems intrigues me. My R450 early nitro motor runs so sweet. Seems like the three problems the later engines display is related to the conversion of fuel to "dryer" gasoline and heat related to its use vrs methanol and its cooler running and additional oil unburnt by the excessive heat?
Sorry guys, excessive covfefe this morning. LOL nervously.
Old 05-21-2021, 07:40 AM
  #50388
acdii
Split the cowl at the centerline of the heads. That will make it easier and give the cowl a more realistic look too. I glued strips of PVC to the top, and had it overlap the bottom so that there was something to screw into with small #2 screws. I used round head allen screws. This is how I attached the Liberty Sport and the Rascal 168 cowls.
Old 05-21-2021, 09:16 AM
  #50389
Glowgeek
PVC strips, great Idea. I've used basswood beams in the past but pvc sounds better, no chance of splitting and semi-pliable. Thanks for the tip.
Old 05-21-2021, 10:52 AM
  #50390
acdii
Acetone melts the strips in place so no chance of them coming off from vibrations either.
Old 05-21-2021, 01:26 PM
  #50391
1200SportsterRider
The firewall is offset 2 degrees to right so the offset verticle centerline sets the prop driver at dead center. Thanks for the suggestions.
Old 05-21-2021, 07:49 PM
  #50392
Hyjinx
Great project! Love the Japanese twins. Lol
Old 05-22-2021, 02:48 AM
  #50393
1200SportsterRider
I am going to make a card material mock up of the cowl side and transfer it to the cowl using the measure twice, cut once method.
Old 05-22-2021, 02:59 AM
  #50394
Glowgeek
I don't really "measure" anything when making cowl cutouts. This vid shows the tried and true method I use.
First used the method on my Sbach and it came out perfect on the first try. Been using it ever since.
Old 05-22-2021, 05:37 AM
  #50395
FlyerInOKC
FlyerInOKC's Avatar
Great method!
Old 05-22-2021, 06:26 PM
  #50396
the Wasp
OK here it is, a video of my first flight
Jim
Old 05-24-2021, 02:45 AM
  #50397
1200SportsterRider
It certainly is different, it flies and that certainly deserves credit. It would be easy to model.
Old 05-25-2021, 03:10 AM
  #50398
1200SportsterRider
Let us suppose a guy, (me) for instance wanted to build a model of this thing and use an FA 30 s for power and a 6" tube. How do I figure the length, wing span, tail feathers etc. An FA 40-a is available also. Some of you may have some software that might help.
1933 Voli
Old 05-25-2021, 03:43 AM
  #50399
1200SportsterRider
Now I'm getting somewhere:
Specs
More coming
Specifications (original Stipa-Caproni)[edit]
ID:	2270398Data from NACA Technical Memorandum nº 753 : Stipa Monoplane with Venturi Fuselage,[5] Aeroplani Caproni: Gianni Caproni and His Aircraft, 1910-1983[6]
General characteristics
  • Crew: 1 or 2
  • Length: 5.88 m (19 ft 3 in)
  • Wingspan: 14.28 m (46 ft 10 in)
  • Wing area: 19 m2 (200 sq ft)
  • Empty weight: 570 kg (1,257 lb)
  • Gross weight: 850 kg (1,874 lb)
  • Powerplant: 1 × de Havilland Gipsy III 4-cylinder inverted air-cooled in-line piston engine, 90 kW (120 hp)
  • Propellers: 2-bladed ground-adjstable propeller
Performance
  • Maximum speed: 133 km/h (83 mph, 72 kn)
  • Landing speed: 68 km/h (42 mph)
  • Service ceiling: 3,700 m (12,100 ft)
  • Time to altitude: 3,000 m (9,843 ft) in 40 minutes
  • Wing loading: 44.73 kg/m2 (9.16 lb/sq ft) at 850 kg (1,874 lb)
  • Power/mass: 0.105 kW/kg (0.064 hp/lb)
  • Take-off run: 180 m (591 ft)
  • Landing run: 180 m (591 ft)
Old 05-25-2021, 04:35 AM
  #50400
FlyerInOKC
FlyerInOKC's Avatar
You certainly won't see another one at the flying field!
