Welcome to Club SAITO !
Old 02-19-2022, 05:36 PM
  #52101
modeltronics
My Feedback: (27)
Hey guys
At one of the swap meets here in Texas I bought a new never run Saito that was totally stuck. Lonnie and I have been going back and forth about this engine for a while and I thought I would post about it here. Along this engines life someone filled it with something. Whatever it was filled with dried out to a reddish-brown goop. It almost looked like someone melted a crayon in it. I was able to get it all cleaned out with 3 in 1 penetrating spray. I now have a nice engine.
What I want to know is what in the world this stuff was. If I ever find out, I never want it in my shop. My guess is it was some type of oil that dried out to this goop. Any ideas?
Old 02-19-2022, 06:19 PM
  #52102
Hyjinx
Originally Posted by Glowgeek
I'm not in a hurry during most of a build. I do get antsy to fly an almost complete model however, one where the last step is to create an inlet baffle and exit opening. A real urgent need to get the cowl on and fly sets in. I think we all experience that.
Originally Posted by modeltronics
Hey guys
Hey Pedro
What is: Cosmiline?
Old 02-19-2022, 07:01 PM
  #52103
the Wasp
thanks for the glue ideas guys! maybe I will just buy more thick CA
LOL but I have another question, LOL how do I get the CH S-Plug Cap off? I pulled and pulled and it wont come off, LOL do I need to pull harder, I can't get a really good grip cause of the head fins.
Jim
Old 02-19-2022, 07:20 PM
  #52104
the Wasp
Hey guys
you know way back I rebuilt a Chevy small block distributer. in one of the pockets in the casting it had some dried up motor oil and it was reddish in color.
Jim
Old 02-19-2022, 07:48 PM
  #52105
the Wasp
BTW guys, LOL I got thinking LOL Oh No LOL
I have read about people saying their fuel has sat in the jugs for 10, 12 years or longer. and they were wondering if the Nitro has evaporated out of it. in fact, one time I even asked that same question because I have some 30% Heli fuel that has sat. well some one replied and told me that most likely all the Nitro has evaporated. well> NOT, because if all that Nitro did evaporate that UNopened jug would have 30% less fuel in it, even if only 5% evaporated, at 6+oz that would be noticeable in an unopen jug.
Jim
Old 02-20-2022, 04:47 AM
  #52106
1200SportsterRider
1200SportsterRider's Avatar
The trouble is that CA eats the foam. As does Krylon paint, when I built the Mudducks I sealed the edges of the Foam Core Board with the Superphatic.
Someone put some "ARO" in that engine that hardened.
Old 02-20-2022, 06:40 AM
  #52107
Jesse Open
Jesse Open's Avatar
Jim
Jim,
I had several 1 gallon cans of Fox Missile Mist fuel well over 35 years old. All in original steel cans that had been stored in a garage. I have now used all but 1 can and had zero problems. I don't use plastic however for long term storage out in the shed. Metal only. Not saying people shouldn't, only saying I don't
Then again, I am a bit particular about hub pullers too! LOL
Old 02-20-2022, 06:54 AM
  #52108
Glowgeek
EPP and EPO foams will melt when using non-CA safe glue, EVA foam does not, at least not so I can tell.
Old 02-20-2022, 07:46 AM
  #52109
FlyerInOKC
FlyerInOKC's Avatar
If your CA eats the foam then you are using the wrong CA. You need the Foam Safe CA made for foam. I have been experimenting Superphatic when I need something to wick into a joint.
Old 02-20-2022, 07:50 AM
  #52110
Jesse Open
Jesse Open's Avatar
Yessir, the guys will crash a foamie, glue it up and they are back in the air in less time than it takes some folks to re-fuel.
Old 02-20-2022, 07:53 AM
  #52111
FlyerInOKC
FlyerInOKC's Avatar
I remember I tried CA when it first came out (Early md 70s) and made the mistake of trying to glue to foam wings together. This was before foam safe CA.
  #52112
acdii
Tightbond III FTW
Old 02-20-2022, 08:31 AM
  #52113
Hyjinx
Originally Posted by acdii
Tightbond III FTW
FTW. Biker Todd? Usually see that tatood on my buddies biceps lol. And nicely patina'ed grey/green. Yall been a bit off topic last few opines about glues. Here's my thought. I acquired a 1/4 zirolli PT17 needing restoration. Not well stored in a garage. I intend to expose the framing for recovering.
Would topically re gluing the framing be best done with a wicking anaphylactic or fortified epoxy?
Old 02-20-2022, 05:42 PM
  #52114
the Wasp
well I got the plug cap off. crazy. it would not come off. left it sitting awhile. went back and pulled on it just a tiny bit and it was off. I had a friend tell me once "when crazy things like that happen it's like it was written in the cosmos to happen that way".
Jim
Old 02-21-2022, 04:28 AM
  #52115
1200SportsterRider
The Saito 100 looks great with a brand new TurboHeader
I like it.
Old 02-21-2022, 04:41 AM
  #52116
1200SportsterRider
That reddish brown residue was air tool oil, I had a couple of gummed up Irvines when I used it.
Old 02-21-2022, 07:56 AM
  #52117
Jesse Open
Jesse Open's Avatar
Yes, the red lacquer AKA air tool oil. I had a pile of brand new engines from an estate. The son said his dad bought them fondled them but never ran any of them. He simply oiled them up with air tool oil and put them away, over twenty years ago. Most every single one was locked up.
Not a single one had ever seen castor.
Old 02-21-2022, 09:10 AM
  #52118
Danker16
I like it.
i make the same velocity stack with the saito 65 choke assembly and the 182t velocity stack, work all the way up to a saito 1.25
Old 02-21-2022, 11:04 AM
  #52119
Jesse Open
Jesse Open's Avatar
Been making them too.Both brass and aluminum.
The brass are handy to make stacks do double duty by recirculating crankcase vented oil. A flanged tube soldered to the side. Keeps the engine bay remarkably clean and dry.
The dual plug Black FA-65 is epoxy powder coat on bottom and factory paint on top.
The dual plug 65 still needs its silicone o-ring.
Also will be getting a new vent on the cam housing.
Old 02-21-2022, 06:41 PM
  #52120
the Wasp
way back I was pumping gas for a living. saw a car pull over on the side of the road. a few minutes later a guy shows up asking me if he could get a cup of gas, yes a cup, told me he only needed enough gas to get the car to the pump. well I said yes, and he went to the pump. well I went out to pump a car and I look over and he has a styrofoam cup full of gas. it was too late it was full. and I stood there and watched that cup disintegrate. out comes the kitty litter.
Jim
Old 02-23-2022, 06:19 PM
  #52121
the Wasp
Hey guys, would Stihl HP Ultra 2st oil be ok for my Saito 120 on gas? or would you rathere see me use someing differnt?
Jim
Old 02-23-2022, 07:29 PM
  #52122
Jesse Open
Jesse Open's Avatar
Hey Jim, we already have a war firing up in the Ukraine. Now why start one here? lol
Really though, you may want to use dino oil gor the first hour or so then go to the sin-thetic stuff.
Really not a huge deal though.
Old 02-23-2022, 07:42 PM
  #52123
Glowgeek
Jim
Stihl Ultra is one of the best 2S oils on the planet, it's all I run in both 2S and 4S gassers. For Saito on gas I use a 15:1 mix. Which 120 are you thinking to convert to gas? 120S or 120 fathead?
Old 02-23-2022, 09:56 PM
  #52124
the Wasp
Gary, the engine has been run so I will use the Stihl.
Lonnie, it's the one in my newly bought 120 4 Star, it's the 120 S and it came with the CH igniter.
thanks guys!!!
Jim
Old 02-24-2022, 01:35 AM
  #52125
Jesse Open
Jesse Open's Avatar
Good choice in that case Jim.
