Welcome to Club SAITO !
Old 04-27-2007, 11:50 AM
  #7151
laryboy
Default RE: Welcome to Club SAITO !
i have a problem with my 90R3. brand new,about 40 oz thru it. 13/7 prop. the max rpm i get is 7500. book says 8500 with 13/7. i also notice that full speed is reached with throttle arm only about 1/2 way to max. running fuel line straight from tank. i have a kleco ring collector w/pressure nipple. engine idles great and transitions smoothly. any body got any ideas?
Old 04-27-2007, 02:32 PM
  #7152
scratchonly
Use a good after run oil and omega 15% or equivilant fuel. I use marine storage fogging oil for aro and haven't had a problem in years.
Old 04-27-2007, 09:13 PM
  #7153
edward cobb
I have a 270 Saito twin, I was hoping that all you Saito fans could give me your best ideas for a aircraft that would be a perfect match for this engine.
Old 04-27-2007, 09:58 PM
  #7154
w8ye
My Feedback: (16)
w8ye's Avatar
It will fly a BUSA 1/3 scale Cub or a Goldburg Super Stinger, or Bridi Big Bee
Old 04-29-2007, 12:40 PM
  #7155
JohnAgnew2978
Does anyone know if Saito discontinued the 150? Horizon doesn't have one on their site. I have one and am looking for another for a Dynaflite PT-19. Also, does the new, slightly bell-shaped muffler have any obvious advantages over the short, cylindrical muffler? Thanks.
Old 04-29-2007, 01:11 PM
  #7156
TimC
TimC's Avatar
John, it looks to me like they still offer it. Here is a link: [link=http://www.horizonhobby.com/Products/RelatedParts.aspx?ProdId=SAIE150&Category=Parts%20Listing&Tag=PF]Saito 1.50[/link]
Old 04-29-2007, 02:39 PM
  #7157
w8ye
My Feedback: (16)
w8ye's Avatar
There is not any difference in sound or power between the current cast muffler and the earlier straight machined mufffler.
The earlier muffler is still available http://www.horizonhobby.com/Products...dID=SAI120S74B
Old 04-29-2007, 08:04 PM
  #7158
onewasp
ORIGINAL: JohnAgnew2978
Yes, it tends to stay assembled on the 150 and 180--------parts for the earlier style are available at the field where I fly (many others as well) they just happen to be in the tall grass!
Old 04-30-2007, 01:05 PM
  #7159
chris_in_montreal
chris_in_montreal's Avatar
Hi all, new Saito 100 owner here. I have been running an APC 15 x 6 prop so far and am fairly pleased with the performance. I do mostly IMAC style flying. I want to try a few other props though for comparison and would really like to try a couple of wood props to see how throttle response changes compared with the heavy APC. Has anysone any experience with the pro zinger or especially the Menz standard wood props on the Saito 100? Any other suggestions? I have seen some new Xoar props around but can't seem to find anyone who stocks them in a 15x6?
Old 04-30-2007, 04:42 PM
  #7160
chris_in_montreal
Any comments on the bolly 15x7 CF prop for a Saito 100??
Old 04-30-2007, 05:09 PM
  #7161
johnS555
My Feedback: (27)
Chris, I use a 13.5-8 Bolly on a couple 100 saitos and it gets the job done pretty good for me, but I don`t do the 3-D stuff, would probably be to much pitch and to short for that....would probably depend on the plane and what kind of flying you want to do, I have them on a 60 Super stick and a Tiger 60....good luck John
Old 04-30-2007, 06:56 PM
  #7162
h9pts
I bought a new saito 82a a few weeks ago. Broke it in according to manual. Since new (now about a gallon through it) it has been unresponsive above 3/4 throttle.
Saito 82a
XOAR 14x6 wood
OS F plug
powermaster 20/20
inverted and cowled on an extra
Idles ok about 2300 when warmed up, transitions great, rpm's pick up until 3/4 throttle and then stop. I can see the carb barrel moving more but no rpm gain. It responds to the hs needle so I don't think I'm starving it for fuel. Spins 9700 rich at 3/4 throttle but when it opens up more it has me wanting more.
Any ideas?
Keith
Old 04-30-2007, 07:04 PM
  #7163
chris_in_montreal
h9pts, where'd ya find your xoar prop??
Old 04-30-2007, 08:00 PM
  #7164
jm_obrien
h9pts, I WAS having the same problem with mine. I also have the 82 and this past Sunday I think it gave up the ghost on me after 3/4 of a gallon. I had help at the field of several Saito owners and we couldn't figure out what the problem was. Out of all my flights I think I deadsticked all but 3 or 4. The engine was in a Chapman Cap 580 and the plane has taken a beating due to the deadsticks that didn't make it back to our asphalt runway[].
After the last time it died in flight and tried to crank it again and it would hardly turn over. Turning the prop by hand it is real tight and I cannot feel the compression stroke so it looks like it may be ruined now. If anyone has any idea what happened PLEASE let me know. I'd love to hear that the valves need adjustment or something simple like that but my luck is not that good.....
Jon
Old 04-30-2007, 08:40 PM
  #7165
N1EDM
IMHO, both cases sound as if it is running too lean, or there was a fuel draw problem (not enough tank pressure, too small a fuel tubing, etc)
My .82 has been a charmer.
Bob
Old 04-30-2007, 08:48 PM
  #7166
NM2K
My Feedback: (14)
Or the vent like was kinked or occluded.
Ed Cregger
Old 04-30-2007, 08:53 PM
  #7167
freeonthree
freeonthree's Avatar
I got my 56 mounted on my new little Pitts last night, and put the cowling on a while ago.
ID:	675581   Click image for larger version
ID:	675582   Click image for larger version
Old 04-30-2007, 09:06 PM
  #7168
jm_obrien
Don't get me wrong, I know these are great engines and tuning was most definately the culprit but right now I'm hoping that something simple needs adjusting or something to get it back running. I plan to call Horizon tommorrow and see what they have to say.
Jon
Old 04-30-2007, 09:26 PM
  #7169
N1EDM
jm, they are probably going to ask you to check the basics first anyway, so verify that you are using the correct size tubing, the vents aren't kinked, the engine isn't running too lean, etc.
Also, how about tank position? Is it too high, too low, or too far from the engine? At least you can have answers to these questions for them when you call.
Just my $.02
Bob
Old 04-30-2007, 09:32 PM
  #7170
Ken6PPC
Jim, have you checked the valve lash? I had a Saito .82 start to dead-stick on me, and I pretty well screwed around with EVERYTHING else trying to get it fixed. I just KNEW the valve lash was right..... Well, it wasn't. Once I adjusted the valve lash, and got the needle valves back to where they were in the first place, it became my favorite engine again. It NEVER dead-stick now - AGAIN!
I don't know what to think about your lack of compression, unless you had the throttle closed. Try putting some light oil down in the glow plug hole, and see if that brings your compression back. If you screwed the needle valves in and out like I did, you might have to go back to the factory-recommended settings and start re-tuning it.
Personally, I doubt your engine is destroyed. It just wants a little attention!
Old 04-30-2007, 09:35 PM
  #7171
blw
blw's Avatar
Hi chris in montreal. Since you have a 100 you are member #516.
Old 04-30-2007, 09:49 PM
  #7172
jm_obrien
Ken6PPC, Man do I hope you are right!
N1EDM, Not only myself but several others at the field that are experienced with the Saitos double-checked everything for me just in case I missed something but it would run fine on the ground level, nose high, on it's side etc. BUT, in flight it seemed that there was no difference from half throttle to full throttle, in fact if you left it 3/4 to full throttle it would eventually lose rpm and die unless I brought it back down to half throttle soon enough. So we thought it was lean....maybe it was??? 2 turns out on high speed and the kicker to me is that three turns out on the low is what was required for it to not sputter from idle transition. On the last ultimate flight it also burned my glow plug which to me is another sign of a lean condition so I'm sure it's due to tuning but we couldn't find the sweet spot for nothing.
Jon
Old 04-30-2007, 09:58 PM
  #7173
Ken6PPC
Jon, have you checked the valve lash yet?
Old 04-30-2007, 10:03 PM
  #7174
jm_obrien
No, not yet. I can only take so much heartbreak a day you know? I just finished rebuilding my Raptor Titan 50 heli. At least I learned something from that experience.....3 mistakes high! Next time I'll listen, sometimes confidence only gets you in trouble. I'll check it tommorrow and let you know what I find, I need some sleep.
Jon
Old 04-30-2007, 10:14 PM
  #7175
freeonthree
If you don't see any smoke at full throttle, fatten up the HSN 1/8 turn at a time until full throttle flight speed starts to reduce slightly, at that point your barely rich, and 1/8 turn it should be about right. Im thinkin you have the HS too lean, and your compensating with the LSN. If my idea seem to help, once ya get the high speed good, lean the LSN 1/16 turn at a time until it doesnt load up at idle and die. If you can remove the fuel line from the carb, and crank the engine by hand slowly, CCW, with your finger over the exhaust, and fuel come out the hose, your fuel delievery is fine. I think it's just a matter of finding the sweet spot for the needles.
