Welcome to Club SAITO !
Old 04-23-2008, 03:47 PM
  #10676
w8ye
My Feedback: (16)
w8ye's Avatar
Default RE: Welcome to Club SAITO !
You may need to run your 170 on the ground some and get is broken in?
It may be too lean?
Old 04-23-2008, 04:20 PM
  #10677
AJsToyz
AJsToyz's Avatar
Two reports ...
1 I flew the YAK with the 72 and the engine performed perfect !! I let it idle the fuel out , I'm glad I had time to kill , that thing idled for about 25 minutes on a high idle.
2 My 1.25 is here and I can put together my Frenzy !!
Andy
Old 04-23-2008, 08:46 PM
  #10678
mbrennan1
I have a Saito 82. It was installed in a pattern plane, Lark 70, that crashed on it's third flight. Plane was destroyed. Motor suffered a lot of damage. Needs new head, intake tube. push rod, and needle valve. I hope everything else checks out OK. I sent it off today to Horizon Service Center for repairs. This motor was new. Any one know how long I can expect it to take? Days-Weeks-Months??? I am also looking for a new pattern plane for this motor-any suggestions?????????????
mbrennan1 Saito Club Member #591
Old 04-23-2008, 08:49 PM
  #10679
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
They are usually really quick.
Old 04-24-2008, 08:35 AM
  #10680
blw
blw's Avatar
ORIGINAL: conchohoncho
Did you redo the member numbers? I have been #260 for a long time.
Richard
Sorry about that. I don't have a copy of the original list kept by the late Bill Robison. I'll remove you from the new number.
Old 04-24-2008, 09:25 AM
  #10681
Walther
Anyone have a source for rocker adjustment screws for an original old 30 SAITO?
Old 04-24-2008, 10:47 AM
  #10682
w8ye
My Feedback: (16)
w8ye's Avatar
I think the current crop will fit but what you get from Horizon will be longer than yours. They will just stick up higher is all. At least that is what I ran into with the newer 30.
Old 04-25-2008, 03:31 AM
  #10683
Mr48Volts
Pleasure to be a member Just wish I could get this 125 sorted out!
Old 04-25-2008, 07:58 AM
  #10684
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I ran two 10mm TurboHeaders on a Saito TS 90 twin yesterday, not much improvement in rpm due to the smallish carb but the sound is awesome. The only way they can used on the TS 90 is with the 90 degree adapters due to the weird angle of the exhaust port. I ran them turned in and turned out, very flexible set up. Incidently, using two Enya #3s I could idle at 2,000 rpm indefinitely.
ID:	936613   Click image for larger version
ID:	936614   Click image for larger version
Old 04-25-2008, 11:04 AM
  #10685
Kmot
My Feedback: (24)
Kmot's Avatar
Will you please record some friggin' video so the rest of us can see/hear it?
Old 04-25-2008, 02:35 PM
  #10686
ShortField
ShortField's Avatar
I lost count as to what number member I would be [8D] but I've got a Saito 1.80 in my Cessna and it's turning a APC 17x8 and some times a APC 17x10
Old 04-25-2008, 03:11 PM
  #10687
Michaelh
ORIGINAL: mbrennan1
I dont know about a pattern plane but I have this and for sure know you'll love it ! http://www.extremeflightrc.com/html/58extra.html
Old 04-25-2008, 03:33 PM
  #10688
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I am going to see if Jim can make me a set of the THs with the pressure tap pointing the same direction as the 10mm threads so they'll point inward when set up on the outside of the adapters. I'll try to get a video in the next few days, my birthday is tomorrow, (66) and I teach Sunday school Sunday. Harley ride Sunday afternoon.
Old 04-25-2008, 03:55 PM
  #10689
Kmot
My Feedback: (24)
Kmot's Avatar
Happy Birthday!
Old 04-25-2008, 06:44 PM
  #10690
AJsToyz
AJsToyz's Avatar
Hey , Happy birthday Hobbsy !!
Old 04-25-2008, 07:00 PM
  #10691
RC Specialties
Hobbsy,
Happy Birthday! I will be in touch on the pressure fitting arrangement.
Jim
Old 04-25-2008, 07:21 PM
  #10692
linkadrip
linkadrip's Avatar
Yes happy birthday to you Hobbsy. That's a really cool set up on that twin too..[sm=shades_smile.gif]
Old 04-25-2008, 08:07 PM
  #10693
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Thanks for the good wishes, my sweety gave me a precision model of a 58 Corvette today and in previous years a 53 Vette, 54 Vette, 57 T-Bird retractible hardtop and an Oliver Super 99 with a 4-71 Detroit Diesel engine. What a wife. She buys me submarine movies for most other holidays.
ID:	936997   Click image for larger version
ID:	936998   Click image for larger version
Old 04-25-2008, 08:33 PM
  #10694
tukkus
can someone tell me what the velocity stack will do for the Satio 82.... I have a new engine and I'm thinking about buy a stack but wanted to know more about it..
thanks
Old 04-25-2008, 08:42 PM
  #10695
TimC
TimC's Avatar
tukkus, here's my post from a thread I started several years ago: "I was mounting a new filter and velocity stack on my .82 this morning and decided to do a before and after test. The fiter is a BruLine and the stack /carb gap was filled with a green automotive air conditioner o-ring that didn't protrude into the air flow hardly at all. The fuel is 15% Omega and the prop is an APC 14x4W. The tank was a 2 ouncer. No linkage was attached to the throttle and the spring held it full open. Here's the results:
No stack /filter: Peak 10,050 richened to 9,650 for the test run. Run time to empty was 2 min. 30 sec.
With stack /filter: Peak 9660, ran at 9360, and the run time was 3 min., 20 sec.
No spitting from the carb was observed before the stack /filter was added."
Old 04-25-2008, 08:44 PM
  #10696
crashnburnrc
Happy Birthday Hobbsy. Hope your here for many more.
Sure is a pretty Harley ya have. Love that color.
Keep your saitos in the air and your feet on the ground.
Old 04-25-2008, 08:47 PM
  #10697
TimC
TimC's Avatar
tukkus, here's another post from that thread: "The engine peaks at 10,170 with no filter and the stack . I didn't do a consumption test."
I picked up 120 rpm with the stack only.
Old 04-25-2008, 09:05 PM
  #10698
Michaelh
Consumption test? Yes , runs very very long time on very, very little fuel. Even on 30%
Im getting 40min+ on my .82 with a 13oz tank, cool power 30%.
Old 04-25-2008, 10:55 PM
  #10699
misfitsailor
misfitsailor's Avatar
Best birthday wishes to a true gent!
Old 04-26-2008, 07:05 AM
  #10700
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
The most amazing thing about turning 66 is that 5 minutes ago I was 20. In that seeming 5 minutes I've raised two kids, worked 33 years and 9 months for the phone company, raced a MAICO, pulled tractors and played with Saitos for 18 years. And a time or two I've played my guitar and sang with w8ye and ran engines in his yard. Thanks all.
