Welcome to Club SAITO !
Old 03-22-2011, 04:46 AM
  #19726
Roo Man
Default RE: Welcome to Club SAITO !
ORIGINAL: Roo Man
OK it's not the preferred engine, but it's all I have. Will it safely power the plane? I do not do any fancy stuff, this would be basically scale flying.
HOBBSY, THANKS FOR THE INFO.
Gary
Just wanted to confirm, I have a FA80 not an 82.
Gary
Old 03-22-2011, 07:42 AM
  #19727
blw
blw's Avatar
You can't really go by the smoke trail of a Saito like you can with an OS. A decent smoke trail on a Saito generally means it is too rich.
Old 03-22-2011, 06:27 PM
  #19728
bpenner697
Gents, I have a FA 100 and have lost the set screw in the HS needle. I have tried set screws from various wheel collars and other misc parts and can't find any that work.
Any suggestions on replacement?
Old 03-22-2011, 08:32 PM
  #19729
w8ye
My Feedback: (16)
w8ye's Avatar
Most of the set screws in the Japanese and Chinese engines are the same. Can you rob a set screw from a needle valve in another engine?
Most of the Great Planes, and Dubro wheel collars are inch and not metric.
Old 03-23-2011, 03:03 AM
  #19730
Rudolph Hart
Rudolph Hart's Avatar
Yes and if you slowly click the needle in between flights you still get way smoky trails and max performance that is repeatable for months of flying.
Old 03-23-2011, 08:20 AM
  #19731
blw
blw's Avatar
I agree with a little smoke, but I meant not like a 2 stroke, etc.
I pretty much tune mine like Hobbsy does. You can pretty much get away with not touching the high speed needle most of the time. Saitos are smooth, powerful, and barely sip fuel when tuned dead on.
Old 03-23-2011, 02:27 PM
  #19732
FNQFLYER
When I say smoke I mean just a little bit not like a 2 stroke.  What kills most model a/c engines is running to lean by having a smoke trail you know fule / oil is going through the engine.  With the YS we have smoke on the ground and a small trail in the air and in case you don't think that is running it hard consider the following an 88inch w/s Feathermerchant (O/T) in 30 secs gives an apparent wing span of the lenght of my little finger.  The model weighs 3.75 pound.  With an 85% Lamzo Bomber with a Saito 65 fitted and set up for duration (30 seconds) same effect with a 13 x 6 Bolly prop, BUT with a Texaco set up (re configged needles both high and low speed to predetermined levels) same model with a 15 x 8 prop in a 5 pound (actually 4 pound 9 ounces) allowance (15mls) fuel load will go to the same height with an engine run of around 6 to 7 minutes.
It is all in the handling of the engine and this is with a new engine as I had to pull the old one after 15 years for a set of bearings to be changed (don't make like they used to)
Lastly it is interesting to see a set of data for running in engines for you guys in the USA as opposed to what we get with our engines directly from Japan.  As I have said before there are marked differences
Old 03-23-2011, 05:09 PM
  #19733
charlie1960
My 100 in it's new home.
and it was getting dark[8D]
ID:	1583252   Click image for larger version
Old 03-23-2011, 06:13 PM
  #19734
bpenner697
ORIGINAL: w8ye
I have looked for a similar size and couldn't find one but I have 2 more 2 strokes I can try. I will also go to a hardware store and look for some very tiny bolts and maybe get lucky and find a set screw. Thanks for the reply.
Old 03-23-2011, 11:18 PM
  #19735
Kostas1
Kostas1's Avatar
Another wicked SAITO!!!!
I recently bought my #3rd SAITO, an FA-80 !!!
(it has the letter -Q- on the mounting base ???? )
I will power my also new, GreatPlanes Cherokee 40 ARF...
[link=http://www.rcuniverse.com/forum/m_10245921/anchors_10411083/mpage_1/key_/anchor/tm.htm#]GreatPlanes Cherokee 40-Saito FA-80[/link]
I think the engine is more than enough!!!
Enjoy...
ID:	1583334   Click image for larger version
ID:	1583335   Click image for larger version
ID:	1583336   Click image for larger version
ID:	1583337   Click image for larger version
Old 03-24-2011, 12:21 AM
  #19736
the pope
Hey there kostas that muffler is fully sick. Ive never seen one like that. Cheers the pope
Old 03-24-2011, 12:34 AM
  #19737
Kostas1
Kostas1's Avatar
ORIGINAL: the pope
Hehee..i know!
Old 03-24-2011, 05:14 AM
  #19738
NM2K
My Feedback: (14)
That muffler should be supported somewhere other than by the cylinder head attachment point. You're asking for a head replacement otherwise.
Ed Cregger
Old 03-24-2011, 05:23 AM
  #19739
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Ed, if my memory serves me correctly that muffler is filled with pieces of fuel tubing that the exhaust has to pass through serving as a diffuser to quiet and engine. They weren't popular nor long lasting. If I'm wrong somebody straighten me out.
Old 03-24-2011, 06:03 AM
  #19740
spaceworm
ORIGINAL: the pope
Re the muffler, it is an Du Bro Arise I thought they were intended for 2 strokes, with their tuning effect, but they were marketed before the increase of 4 stroke popularity (I think).
Regards, Richard/Club Saito #635.
Old 03-24-2011, 06:16 AM
  #19741
spaceworm
I am thinking that there was a plate baffle with holes into which pieces of fuel line were inserted????????. I guess you could tailor the tuning or muffling by changing the length or size of the tubing??????? I could be wrong, my memory often fails me.
Old 03-24-2011, 06:56 AM
  #19742
earlwb
earlwb's Avatar
Dubro made at least two different mufflers under the Arise label. A 2 stroke and a 4 stroke version.
The two stroke version has multiple steps to fit different diameter mufflers and you remove the back half od a OEM muffler and plug the Arise in accordingly. It was fairly expensive and it did work. But I suspect modellers were turned off by the cost of it,
Here is the two stroke version.
Old 03-24-2011, 01:36 PM
  #19743
Rudolph Hart
It kinda looks like a smoking implement
Old 03-24-2011, 03:55 PM
  #19744
radial1951
Lots of interesting stuff here, especially on setup and tuning. I didn't realise the break-in can take so long.
Re the radials: does anyone actually prime the engine using the syringe method? I've never seen it mentioned on any forum...
Regards
radial1951
____________________
Old 03-24-2011, 04:08 PM
  #19745
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
According to Saito the engines are ready to fly in 40 minutes, just keep it a little rich for another hour and have your way with it.
Old 03-24-2011, 04:28 PM
  #19746
NM2K
My Feedback: (14)
ORIGINAL: Hobbsy
I wondered how the interior was configured in that muffler.
Good to see you posting again, Dave.
Ed Cregger
Old 03-24-2011, 04:54 PM
  #19747
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Thanks Ed, and just to do something for my self I'm going to Mechanicsville, Va. Saturdey to an RC Flea Market and FlyIn. I can't afford anything but ima goin. I'm gonna hang out with Spaceworm and G. Graham.
Old 03-24-2011, 11:20 PM
  #19748
Kostas1
Kostas1's Avatar
Hobbsy,
could you please remind me the #Number of the Club Saito member i am ???
Old 03-24-2011, 11:32 PM
  #19749
w8ye
My Feedback: (16)
w8ye's Avatar
BLW has the Saito Club numbers
It is best for you to put your number in your signature when you find out what it is.
Old 03-25-2011, 02:23 AM
  #19750
Rajib
Rajib's Avatar
How to become Saito Club number?
