Welcome to Club SAITO !
Old 02-23-2012, 12:11 PM
  #21626
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Default RE: Welcome to Club SAITO !
Check here, there is a .5" drill bit with a .25" pilot. Dick Bennett passed away last September but It looks like someone is still trying to carry on.
http://bennettbuilt.com/catalog_pages/page9.htm
Old 02-23-2012, 12:49 PM
  #21627
mjraines1
Thanks for the info. on B & B I have tried to contact them on several occasions. No one answers and the fax is not hook up. the .25 pilot and .50 bit is exactly what I need. Any thoughts on where else I might find one of these?
Old 02-23-2012, 04:14 PM
  #21628
retransit
My Feedback: (18)
retransit's Avatar
Anyone have any info on the new Saito 1.80B? Horizon says it has a new case. Seems to be the outside dimensions of a 1.25.
Bob
Old 02-23-2012, 05:55 PM
  #21629
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
That case is the new style case like the 2.20. 115, .82 b .40a and 1.00 have. It appears that only the .62 and 150 are left in the old case.
Old 02-23-2012, 06:16 PM
  #21630
hsukaria
ORIGINAL: Hobbsy
What!?? So my 1.8 is now obsolete? Doggone!!
Old 02-23-2012, 06:20 PM
  #21631
mike early
mike early's Avatar
ORIGINAL: mjraines1
I have the 91 Satio with the short adapter from Tru Turn, The inset into the prop is 1/2 ' and 3/8' deep. This is on a prop 3/4' thick. (50%).
If you use a drill bit the shaffer beyond the bore is a little more than 3/8? It is difficult to get a true 1/2 in hole with a drill bit? I use a high speed counter sink? This works well but you still go beyond the 3/8 with the bottom depth. You need somethng like a Fostner bit that will take you the 3/8 and be flat on the bottom?
I have made numerous request to tru-turn with no reply? They once said to use a pilot drill with a 7mm shaft and 1/2 inch Dia. at the bore. You can get one of these custom made for $123.00? I don't think this is for me? Not for just a few props? You don't have to do all this with Dave Brown?
Any ideas ?
The prop adapter ridge inserts into the tru-turn washer, not the prop. The washer hole is larger than the prop shaft. The ridge keeps it centered.
Old 02-23-2012, 06:35 PM
  #21632
mjraines1
Thanks, I'll try again tomorrow. I called several times today. He has what I need in the cat. I'll see if I can fax him a order tomorrow. So far I have been unsuccessful in getting intouch with anyone there.
Thanks again.
Old 02-23-2012, 06:43 PM
  #21633
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
MJ. I think you have the one on the right.
Old 02-23-2012, 06:47 PM
  #21634
mjraines1
I think you will find that on the short shaft adapter for the 1' shaft the adapter goes through the washer and then sets 3/8 of an inch into the prop hub. This has to be drilled to 1/2 inch dia. 3/8 inch deep and should use the 0.25 hole in the prop. to index to get a true 1/2 inch hole in the prop to align properly. This should be drilled so the prop nut seats flush aganist the prop at a depth of 3/8 in. A regular drill bit or countershink will usually have about a 92 degree angle on the bit so by the time you get 3/8 of an inch into a 3/4 in thick prop plus the amount used for the angle, you don't have much let for the prop?
Your suggestions are appreciated? Do you know of anyone using a Tru Turn Spinner and short adapter on the Satio that has encountered a similar problem?
  #21635
mike early
mike early's Avatar
Oof, throw that away and buy the one on the left. Works on all props and is cheaper than specialized tools.
Old 02-23-2012, 06:49 PM
  #21636
mjraines1
You are correct, you can see where the adapter comes thru the washer and leaves about 3/8 of an inch that must inset into the prop hub.
Old 02-23-2012, 06:51 PM
  #21637
mjraines1
If the one on the left will work on the short shat and still leave room for the lock nut, I think that may be the way to go?
Old 02-23-2012, 06:52 PM
  #21638
mjraines1
Hobbsy,
Will the adapter on the left work on the short shaft using the lock nut adapter?
Old 02-23-2012, 06:57 PM
  #21639
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
The inside wood doesn't matter the washer creates the holding pressure.
Old 02-23-2012, 07:03 PM
  #21640
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Here's your guy if you have 7mm shaft. Part #TT-0717-A
Woops, I left out the link, http://www.truturn.com/cgi-bin/store...dapt0717a0716a
Old 02-23-2012, 07:15 PM
  #21641
mjraines1
Yes this is what I have? How about the one you pic on the left. Will it fit and does it have the lock nut? What's the part No. on it?
Old 02-23-2012, 07:17 PM
  #21642
mjraines1
What is the part No. on the one you are using?
Old 02-23-2012, 07:23 PM
  #21643
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
No lock nut and only gains you the thickness of the washer. The one on the right gains quite a bit more but again, no lock nut.
Old 02-23-2012, 11:07 PM
  #21644
FNQFLYER
Old fart, I usually play with various different props and fuel mix combos to determine what the max rpm that any particular engine will give. My best example is my pair of YS 63's (one of each series) on Bolly 13.5 x 6 and 6.5's I can get up to 500rpm difference in performance depending on the oil mix for the engine.
For out right power extraction I use Bolly props for Texaco type economy I use Master airscrew and for anything else I use APC keeping an eye out for stretch marks at the blade root to hub area
Old 02-24-2012, 06:11 AM
  #21645
Rudolph Hart
Rudolph Hart's Avatar
Yes agree with your comments and thanks for that.Specifically i was looking at the prop figures the author was quoting for the saito 100 petrol engine claiming 8715 on an apc15x8.I can get that on my 115 running 10% nitro but it's on the lean side,hence my question
Old 02-24-2012, 07:14 AM
  #21646
SrTelemaster150
SrTelemaster150's Avatar
ORIGINAL: Hobbsy
Check here, there is a .5'' drill bit with a .25'' pilot. Dick Bennett passed away last September but It looks like someone is still trying to carry on.
ORIGINAL: mjraines1
A piloted drill bit IS NOT a counterbore!
Be carefull here.
You can achieve the same thing as a piloted drill bit W/a 1/2" standard bit if you have a drill press. (which you should have in any case for this operation)
Besides, the hole in the priop needs to 7mm doesn't it? A 1/4" pilot will be useless unless you are just using a blank prop #W/a 1/4" pilot hole.
Old 02-24-2012, 08:55 AM
  #21647
triumphman49
My Feedback: (149)
Hi SrTelemaster150
Had some earlier postings concerning converted saito's using E85 fuel, and have some questions concerning oil mixes.
Been using Stihl Ultra HP @32:1 for gassers, & planned to go to 20:1 for converted 270T using gas (also FG20 & FG36).
For E85 usage, should the oil mix be increased to 15:1 or more?
I've read that gasoline has some inherent lubricity & E85 apparently doesn't have much gas in it.
T-man49 in Al
Club Saito #723
Old 02-24-2012, 09:05 AM
  #21648
Lancaster 52
My Feedback: (72)
I have some Saito FA - 325R5 parts I want to sell and I would like to know what a fair asking price would be.
I have a gasket set part # 325-32 for the FA-325R5 that's new in the Saito package and 2 sets of part #325- 72/73 Exhaust pipe/Gasket Set, also new in the Saito packages which I don't think are available anymore.
Bill
Old 02-24-2012, 09:07 AM
  #21649
Lancaster 52
My Feedback: (72)
I have a gasket set part # 325-32 for the FA-325R5 that's new in the Saito package and 2 set of part #325- 72/73 Exhaust pipe/Gasket Set, also new in the Saito packages which I don't think are available anymore.
Bill
Old 02-24-2012, 02:01 PM
  #21650
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
The hole in the prop matters not, the .5" shoulder on the adapter locates the prop. Most props have a .25 in hole and is the reason for the .25" pilot on the drill.
