Welcome to Club SAITO !
#2401
RE: [Awaiting Approval]
Thinking I might try some ATF for afterrun oil in my Saito, I looked at a bunch of it in the auto parts store. Dexron III, right, Bill and others? Any particular brand or price range? There was quite a variance.
Ernie
Ernie
#2402
Ernie:
Right. Dexron III.
In order for it to be labeled "Dexron III" it has to pass the API certification. So, the least expensive brand labeled "Dexron III" is the best buy.
In effect, all of them come out of the same barrel, then get different brand names on the bottle.
Bill.
Right. Dexron III.
Bill.
#2403
My Feedback: (24)
RE: Welcome to Club SAITO !
ORIGINAL: lrr
It looks like the jaws will need a fair amount of grinding to fit, and the ends of the three arms sawed off to allow the front ends to pivot close in to fit the engine squarely.
#2406
PA
welp in the last week ive pruchased my first 2 saito engines, a 65 and an 82.
What motor mount should i use with the 82 ? I'm mounting it on my astro hog.
#2409
PA
very heavy mount, and the saito 82 is a very narrow motor, the 60-120 has to be almost as narrow as it will go for the 82
ORIGINAL: w8ye
I like these mounts for a four stroke
http://www2.towerhobbies.com/cgi-bin...?&I=LXJ773&P=7
#2410
CA
This one is smaller:
[link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJ772&P=7[/link]
This one is smaller still:
[link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJ771&P=7[/link]
I think that W8YE's point was that the GP adjustable mount, reguardless of size, is a simple and mechanic proof mount.
I'll hold judgement on the mechanic proof-ness untill I've had a chance to use mine.
#2411
were does the mixture screw end up about on a saito 72 im at 1 1/4 but think im still rich haven a hard time with the tach . its reading up and down new to 4 strokes thanks for any help edit to ask the tach i have is a clobee is this a good one ?
#2413
spec36:
The HS at 1 1/4 to 1 1/2 is in the ball park for an FA-72, but on what is usually the lean end of its range. Set the HS ONLY at full throttle, and do not change it trying to adjust the mix at lower settings. The LS is the main control up to about 1/2 throttle, and still affects the mixture as far up as 3/4 throttle.
With the HS set adjust the LS for a good transition, then keep leaning it a little at a time until the engine stumbles a bit on opening the throttle. When you get to this point open it a very little at at a time until the tumble goes away. All should then be fine.
The old "Quick and Dirty" mixture check is to pinch the fuel hoe, when the settings are right the engine should pick up a little rpm before falling off.
gumhead:
Why do you think having a DeWalt cordless drill gets you in the club?
Haw.
Bill.
gumhead:
Haw.
Bill.
#2415
MA
ORIGINAL: William Robison
gumhead:
gumhead:
#2419
MA
Its a GP Slowpoke. Its almost ready for covering... Im gona be using Sig Koverall and dope so its will be a little longer before its done...
More pics of the build can be found here...
http://www.gumhead.com/gumhead_pics/...oke/index.html
#2420
GA
I have the ring for my 1.20. I do not want to break it so how do you get it on easy. I read through this long thread but gave up on like page # 20 something.. I have the bearings on the way..
LATER
LATER
#2425
MA
ORIGINAL: powerlines
That is the drain for the oil. Connect fuel line to it so it will run out of the plane..
LATER
LATER
