New 1/4 scale build starting
grbaker (07-04-2022)
The following 3 users liked this post by jerrybern:
#106
I didn't like how the canopy fit so I decided to mold into the hatch. I made a template of the canopy then traced on the cockpit and used a dremel tool with a router base to cut out the slot.I had to use some epoxy and micro balloons to feather it in. I then sprayed on primer to blend it in.Now I have to repaint a part of it, however the latex paint blends in very nicely. Next step is a little more weathering, then the satin clear coat, putting the turbine back in and programming the radio Till Next Time! Jerry B
#107
I gor it all blended in now, touched up the paint.,I am going to let the paint cure for the next 5 daya while my wife and I are on a short vacation. Till Next Time ! Jerry B
#108
It is the first time on it's tires in the sunlight,after three years this project is coming to a end.First flight should be before Labor day, if there are no problems.
grbaker (08-13-2022)
